Quantcast hardtop repair - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > hardtop repair
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 11-03-2009, 08:01 AM   #1
PASKS
2010 JK Wrangler
hardtop repair
i am sure this is a common problem and someone has had to deal with it. my passenger side rear gate "shock" that holds up the rear gate is pulling the fiberglass apart and will soon tear free. what can i do to reinforce this area to get more life ?
PASKS is offline   Reply With Quote
Old 11-03-2009, 06:45 PM   #2
Jesse_87
x2 Same problem here.
Jesse_87 is offline   Reply With Quote
Old 11-03-2009, 06:50 PM   #3
bentshackle
1983 CJ7
I cant speak to hard tops specifically but its pretty amazing what you can do with West systems epoxy and glass cloth. Fixed a crunched stern and a broken fitting on a glass boat this week alone. Take your time, dig, grind out all the loose glass, lay the new glass up, re prep, re lay, lather, rinse, repeat. Glass work takes time to do well but it is as strong or stronger if its done well
BS
'83 CJ7 my engine compartment is the previous owner's tragic legacy and a cruel joke.
'99 Volvo S70
People who don't like having their beliefs laughed at shouldn't have such funny beliefs
bentshackle is offline   Reply With Quote
Old 11-03-2009, 06:55 PM   #4
PASKS
2010 JK Wrangler
i was thinking about trying to squeeze epoxy between the "fiberglass" interior and the outside skin and holding it tight till it dries. OR trying to mount a metal plate to spread the load out farther....
Old 11-03-2009, 09:04 PM   #5
shaggyjim
shaggyjim's Avatar
My hard top was in a roll over. I put it back together with this stuff. Works like a champ.http://www.marinetex.com/
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
"I love cats, I just can't eat a whole one!"
shaggyjim is offline   Reply With Quote
Old 11-03-2009, 09:37 PM   #6
JohndKc
JohndKc's Avatar
1987 YJ Wrangler
I just did that this weekend, but it only worked for a little bit. I am going to go out and buy a piece of 1/8" plate my next day off and mount it through the figerglass. I am then going to use some good silicone to seal it.
If i had the chance i wouldn't do the epoxy again. It made more of a problem then it helped. I had to scrape it out without separating the fiberglass anymore. I got it all prepped and ready for this weekend. Will post pics if i get around to doing it.
JohndKc is online now   Reply With Quote
Old 11-04-2009, 11:34 AM   #7
jharsany
I had the same problem on mine. I pryed apart the two layers of fiberglass and pushed epoxy in there as best as I could. I also added some screws/washers/nuts that go behind the weatherstripping and through the shock bracket inside. So far so good. I can get pics if anyone is interested.
jharsany is offline   Reply With Quote
Old 11-04-2009, 11:46 AM   #8
PASKS
2010 JK Wrangler
id like to see it !
Old 11-04-2009, 01:24 PM   #9
dodger889
lost in the woods
dodger889's Avatar
Use some metal support to spread the load being caused by the lift shock. Then do a fiberglass repair cover to the bad spot.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Old 11-04-2009, 02:22 PM   #10
dagoober
i just put some new fiberglass on mine. hand laid fiberglass is waaay stronger than what the hardtop is origonaly.
dagoober is offline   Reply With Quote
Old 11-04-2009, 04:48 PM   #11
Chris
I do stuff
Chris's Avatar
I would suggest just doing fiberglass as even with a plate it will only be temperary. They are made of fiberglass but just not a strong point in that area so why not just reinforce it with what it is made out of and it is really simple and kinda fun.
Got any plumbing questions? Are you a plumber? Need another general discussion to hang out in?
Check out plumbingforums.com
Need another Wrangler forum?
Check out wranglerboard.com
Chris is offline   Reply With Quote
Glock Forum
