Hardtop question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hardtop question
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-03-2015, 08:42 AM   #1
wrangler_bear
Hardtop question
Recently purchased a hardtop for my 93 wrangler. Bought the lange quick release kit to secure the hardtop to the jeep. Im a little concerned about the aluminum rivets that were supplied. Although they are good for anti corrosion they are not as strong as steel rivets or stainless steel rivets. Im concerned about corrosion because of storage outside during the spring and summer months. The latches appear to be made of steal and are not stainless. Anyone know of any other good hardware that won't be subject to corrosion and can withstand the stress?
wrangler_bear is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 08:52 AM   #2
TCazes
shoot i use el cheap aluminum rivets and never had a problem with mine. think you are over thinking it.
TCazes is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 09:13 AM   #3
TheGanzman
Agreed - The hardtop is almost completely held down by the "rail bolts" on each side - I drove my '91 for months with NO front attachments whatsoever at freeway speeds...
TheGanzman is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 09:48 AM   #4
Anticanman
The Thunder Chunky
Anticanman's Avatar
It doesn't rain enough in the summer to worry about corrosion.
Hell, it doesn't rain enough in the winter either!!
Luck Favours The Prepared
Originally Posted by rambo3489 View Post
Listen to what the canman says. You don't have to take it all word for word. But at least listen to the man. He knows his ****. Its a no BS straight to the point realistic approach to things. You may not like it. But someday you might have an Anticanman moment. Like you just had. I know I have. Hell I had 2 last week.
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 09:48 AM   #5
wrangler_bear
Thanks for the replies. Now what about corrosion on the front latches when stored outside?
Unread 05-03-2015, 09:49 AM   #6
Anticanman
The Thunder Chunky
Anticanman's Avatar
Just give them a little rubdown with gun oil before you store it and they'll be fine.
Unread 05-03-2015, 09:57 AM   #7
wrangler_bear
Thanks guys. I will begin riveting with the aluminum rivets and steel latches.
