Hardtop Defroster Won't Work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hardtop Defroster Won't Work
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting SleevesJeep Grand Cherokee Grills
Unread 04-05-2009, 03:47 PM   #1
442Wrangler
In like Flynn.
442Wrangler's Avatar
So i've had my jeep awhile and i just got around to fixing this problem but the hard top defroster doesn't work at all. ive checked all the fuses and they are just fine. what the heck is the problem?
and the light on the switch doesn't turn on by the way.
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1998 TJ Sahara Sold
-3.25" RC spring lift, Eagle alloys 125s, 33x12.5x15 Cooper STTs, XRC8 winch with stock bumper mount
1994 YJ SE Sold
-4" RC spring lift, 33x12.5x15 Firestone M/Ts, Eagle alloys 125, and a 4 cylinder to boot
1960 Willys Wagon
-Going to be restored and painted Omaha Orange
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
Male RN Jeep Club #1
442Wrangler is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 05:08 PM   #2
Mark05059
check for power getting into the switch first... then move to power out of t he switch... then power getting to the back of the jeep...etc.. electricity is like water... either you have it or ya dont
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 05:16 PM   #3
SnowdogMarc
I have to disagree with you on that one my friend. I was troubleshooting a friends truck who had no parking lights in the back. If I pulled the bulbs out there was 12v at the socket. Put the bulb or a load on the circuit and it dropped to like 2 volts. I started tracing the wires back and found a bad connector under the cab.
You could have a bad ground causing all your problems.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 07:01 PM   #4
CjinPA
CjinPA's Avatar
Check the connection at the rear window. Mine slide off all the time when I open the rear lift gate.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 07:36 PM   #5
442Wrangler
In like Flynn.
mine are connected and to the shocks...i hadda sodder one on today because the plastic thingy broke. =/
2008 JK Rubicon
1998 TJ Sahara Sold
1994 YJ SE Sold
1960 Willys Wagon
-Steve McQueen
Unread 04-05-2009, 10:31 PM   #6
dodger889
Check for power to the connector at the window and the wires coming out of the top. Then check left rear corner for the connector going up the top. Then check by the e brake peddle connector and the switch. Actual go the other direction. But this gives you all the location to where the connector are.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote Quick reply to this message
