hard top on soft top? - JeepForum.com
post #1 of 4 Old 10-21-2002, 06:33 PM Thread Starter
blue4banger
i was wondering if you have a soft top model yj can a hard top be added as well?
97' blue 4 banger, hard top, OME 2.5 inch lift, 1 inch body lift, 3/4 inch coil spacers, 33 x 12.50 Goodyear Wrangler MT/R's...
blue4banger is offline
post #2 of 4 Old 10-21-2002, 06:43 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Yes, as long as all the soft top hardware and brackets are removed.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 4 Old 10-21-2002, 07:32 PM
jmeyer722
you'll also need to see about doors. if you have half doors (which i'm assuming you do) you'll have to get the fiberglass uppers. hard tops have rounded door openings & soft tops have square openings.
1995 Jeep Wrangle Rio Grande, 4" Superlift, 32x11.5x15 BFG Mud Terrain on American Racing AR-136 Wheels, Pioneer CD Player, 12 Disc Pioneer Cd Changer, 2 8" Rockford Fosgate Subs mounted under back seat, Punch 100 amp under drivers seat, Factory hard top w/full doors, Factory soft top w/half doors, Bikini top, Duster cover, K&N filter,...More to come
jmeyer722 is offline
post #4 of 4 Old 10-22-2002, 07:04 AM
Meister_jeep
blue4banger I was just wondering if you were in the right forum cause your jeep is a 97 which would make it a TJ not a YJ. But we will still help you out
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
hard top vs soft top str8stock4l TJ Wrangler Technical Forum 26 08-25-2009 01:20 PM
Soft Off Hard On BlueTeeJay TJ Wrangler Technical Forum 4 09-28-2006 01:01 PM
hard or soft top? brundz YJ Wrangler Technical Forum 15 07-26-2005 10:40 AM
Hard top to soft top? Wilson YJ Wrangler Technical Forum 1 07-07-2004 10:53 AM
Hard top or soft top??? nuclear ape YJ Wrangler Technical Forum 12 02-07-2002 06:41 PM
