Hard Top Restore - JeepForum.com
post #1 of 8 Old 01-09-2010, 08:27 PM Thread Starter
jason8425
Hard Top Restore
Started the sanding of my hard top today. Has anyone had any experience in using some type of rattle can spray on bedliner for this? Any recommendations to what kind is best? Is it difficult to spray on and look decent? By the way it is an aftermarket top and will be starting from fresh fiberglass when i finally finish sanding. Thanks!
jason8425 is offline
post #2 of 8 Old 01-09-2010, 09:30 PM
Gorilla_97
I would personally use the bedliner rattle can. The texture will hide alot of imperfections and can be easily be touched up from time to time. If I can ever find a YJ hardtop in Texas I will do this to mine!
Gorilla_97 is offline
post #3 of 8 Old 01-09-2010, 09:34 PM
ReconBen
1987 YJ Wrangler
Dupicolor spray on bedliner worked fine on mine came out pretty damn good. just as long as you keep the same distance from the hardtop everywhere you spray you shouldn't have any troubles. if you put on two coats it looks great and drys pretty damn hard and doesn't get scratched up easily at all.
ReconBen is offline
post #4 of 8 Old 01-10-2010, 06:08 PM
ruffneck460
1987 YJ Wrangler
Rustoleum spray on bedliner works very well and has a nice texture as well.
ruffneck460 is offline
post #5 of 8 Old 01-10-2010, 06:11 PM
iowajeepers
I did mine this summer. Rattle can flat black with a satin clear coat.
1994 YJ, 2004 WJ, 1976 C3, 2015 Slingshot, 2001 ZX6r
iowajeepers is offline
post #6 of 8 Old 01-10-2010, 06:11 PM
yjmudder90
x2 i did my entire jeep (minus hardtop) with this stuff and i love it!
1990 yj, 4.2, ax-15, 2.5" RC lift, 1/2" boom shackles, Herculiner inside, duplicolor outside, 33x12.50-15 Interco trxus mt's, Hacked body,
"The right of the people to keep and bear Arms shall not be infringed."
yjmudder90 is offline
post #7 of 8 Old 01-10-2010, 06:25 PM
youngYJ95
i used the rustoleum that had a texture to it so it was gritty. came out wonderful! used four cans, a can of primer and then a clear coat. it was the dark spice color. i highly recommend the rustoleum. its cheap too by the way
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate]
youngYJ95 is offline
post #8 of 8 Old 01-10-2010, 06:26 PM Thread Starter
jason8425
Thanks for the info! Think I will give it a try.
has anyone ever used restore orenjr TJ Wrangler Technical Forum 2 10-02-2008 05:18 PM
yj restore kennyk YJ Wrangler Technical Forum 28 04-06-2008 02:25 PM
Your thought's on Restore Engine Restore... NewhampshireYJ YJ Wrangler Technical Forum 12 02-07-2008 05:44 AM
'92 YJ - to restore or not? Dianne YJ Wrangler Technical Forum 4 11-13-2006 11:22 AM
Hard Top Restore motornon TJ Wrangler Technical Forum 6 05-23-2005 11:20 AM
