hard top repair? - Page 2 - JeepForum.com
post #16 of 25 Old 02-19-2012, 08:37 PM
Old4X
1990 CJ7
Personally I would do an original "Body by Fisher". Fisher used to make car and truck bodies from wood. I would cut a piece of 3/4 inch plywood and line it up with my already installed bulkhead.
Then use epoxy proof foam blocks and glue to the cut top and plywood piece. Sand and carve the foam to shape, and cover with glass and resin.
The complex curves in the fiberglass will give lots of strength. Would probably imbed some sheetmetal reinforcement clips in 4 or 6 places, and cover well with glass.
This is how some of the super-slick homebuilt airplanes are made these days.
The work is mostly in the setup and measuring, the actual glassing is secondary.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #17 of 25 Old 02-19-2012, 08:39 PM
Old4X
1990 CJ7
Once the rear wall is done, find a window you like, and cut an opening for it, and install it.
Old4X is offline
post #18 of 25 Old 02-19-2012, 09:34 PM Thread Starter
k-bar
sweet, I am def ready to do this now!!
k-bar is offline
post #19 of 25 Old 02-19-2012, 09:35 PM Thread Starter
k-bar
Oh and where can i get some epoxy proof foam blocks?
k-bar is offline
post #20 of 25 Old 02-19-2012, 09:42 PM
Old4X
1990 CJ7
http://www.aircraftspruce.com/
You might find it locally, but these folks definitely will have everything you could ever need.
Old4X is offline
post #21 of 25 Old 02-20-2012, 06:04 PM Thread Starter
k-bar
All the foam on that site is compatible with epoxy. I cant find any that is epoxy proof
k-bar is offline
post #22 of 25 Old 02-20-2012, 08:10 PM
Old4X
1990 CJ7
You will need to research the current materials, most of my work was in the late 80s. I did some fabrication at that time. Since then only repairs and touch-ups.
I used blue polystyrene, mainly because I was doing a lot of hot-wiring.
From my catalog, it appears Last-a-Foam works well also.
You will want one of their catalogs, very instructional.
Old4X is offline
post #23 of 25 Old 02-20-2012, 08:27 PM
Old4X
1990 CJ7
Epoxy proof/ epoxy compatible, would be the same for your requirements.
Some foams have wider resistance to glues, solvents, fuels, etc, and I tended to work on different and odd projects, so I stayed with the most compatible for my uses. There may be plenty of other formulations available today that will do what you want. Plus if you hot-wire the wrong foam, it produces poisonous gas.
Epoxy is the most forgiving IIRC as to compatibility, but it is several times the cost of some other resins, so there is a trade off.
Old4X is offline
post #24 of 25 Old 02-20-2012, 09:11 PM Thread Starter
k-bar
Whom's catalog?
Thanks again for all the great info btw. You def seem to know what you are talking about.
k-bar is offline
post #25 of 25 Old 02-20-2012, 09:55 PM
Old4X
1990 CJ7
Whom's catalog?
Aircraft Spruce
Old4X is offline
Hard top repair samiam2714 TJ Wrangler Technical Forum 0 07-10-2011 02:04 PM
how to repair a hard top tyvan JK Wrangler Technical Forum 5 12-18-2009 12:54 PM
Hard top repair gumbydammit TJ Wrangler Technical Forum 7 05-26-2009 05:02 PM
Hard Top Repair YJ-Mike YJ Wrangler Technical Forum 6 04-08-2006 05:05 PM
Repair of Hard top 2_fast4u TJ Wrangler Technical Forum 4 01-16-2006 05:56 AM
