Hard Top Removal - JeepForum.com
post #1 of 12 Old 03-01-2011, 08:39 AM Thread Starter
mudbug99
Hard Top Removal
Good morning everyone. Just recently purchased my first Jeep, a 1992 YJ. It currently has a hard top that I'm trying to remove. Purchased a torx T40 wrench but was unsuccesful in unscrewing it, possibly due to rust or maybe me being too weak.. highly doubt that though. What suggestions do you guys have out there for removing this top? Thanks
mudbug99 is offline
post #2 of 12 Old 03-01-2011, 08:43 AM
jaycal3
... turn harder? If you are referring to the bolts that hold it to the tub just lean into it a bit. I cant imagine rust holding them on. There should be inserts on the bottom side... make sure they are not spinning although they shouldnt due to their shape.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #3 of 12 Old 03-01-2011, 08:43 AM
Big4mike9
Where are there torx screws for the top??
93 YJ.......Under Construction
Big4mike9 is offline
post #4 of 12 Old 03-01-2011, 08:48 AM
SPCMilligan87
1987 YJ Wrangler
It can be a pain in the @$$ if it has never been removed. I used to have a 2002 wrangler sahara with a hard top.
After stripping out 4 of the 6 torx bolts I took a grinder and carefully made a flat spot on each side of the bolts so I could get them with a 1/2" open end wrench. I got online ordered new bolts, put alittle bit of grease on them and never had a problem after that. Now I have a 87 yj with a softtop, so much easier to deal with.
SPCMilligan87 is offline
post #5 of 12 Old 03-01-2011, 10:10 AM Thread Starter
mudbug99
The 4 torx screws are in the rear of the jeep holding down the hard top, 2 on each side.
mudbug99 is offline
post #6 of 12 Old 03-01-2011, 10:26 AM
Hbeaudreau
1987 YJ Wrangler
mine aren't torx bolts, mine are just bolts. I've never had this problem with my 87'. the top always seem to come off quite easily with the help of someone to lift it up
So what if my Yj is 5 years older then I am?
63 Scout 80 - 196 L4, 32 KM1's, SOA
87 YJ- 4.2TBI, Dana 44's, 35 KM2's, SOA
YJ Build : http://www.jeepforum.com/forum/f12/my-87-yj-build-thread-1072026/
Hbeaudreau is offline
post #7 of 12 Old 03-01-2011, 10:41 AM
Big4mike9
Hmm mine are big Phillips screws and I have 4 on each side and no problems. But I just bought some thumb bolts. So no tools needed.
post #8 of 12 Old 03-01-2011, 10:52 AM Thread Starter
mudbug99
You guys are lucky by just having philips screws. Two of the 6 were philips and came off nice and easy. These torx are just beyond difficult and the weather in Houston is perfect for the top off.
mudbug99 is offline
post #9 of 12 Old 03-01-2011, 11:07 AM Thread Starter
mudbug99
Do any of you have any recommendations of maybe taking it somewhere to have it removed?
mudbug99 is offline
post #10 of 12 Old 03-01-2011, 11:56 AM
jeep795
If you didn't strip them out then just keep trying. Spray some pb or wd or something overnight. try a longer ratchet or maybe a small pipe for an extension.
jeep795 is offline
post #11 of 12 Old 03-01-2011, 12:31 PM
giggityjeeper
weird there should be 4 each side...... LOL...... not just 4
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #12 of 12 Old 03-01-2011, 01:04 PM
SPCMilligan87
1987 YJ Wrangler
I will be in Houston the whole month of April with my jeep so i hope the weather stays good. Too bad spring creek offroad park isnt open anymore. .Are the screws stripped or are they just not turning? If there not stripped you gotta put some more muscle into it. Just dont break your side glass on the top.
Hard Top Removal nhjku JK Wrangler Technical Forum 24 05-31-2010 02:53 PM
Hard top removal. Deadhorse TJ Wrangler Technical Forum 20 04-25-2009 04:34 PM
hard top removal GIJoe Driver JK Wrangler Technical Forum 1 04-09-2007 07:09 PM
Hard Top Removal Texan4life TJ Wrangler Technical Forum 12 03-07-2005 05:01 PM
Hard Top Removal Inukshuk YJ Wrangler Technical Forum 4 02-09-2004 12:04 AM
