hard top question - JeepForum.com
post #1 of 5 Old 10-28-2007, 06:47 PM Thread Starter
Crotalus
hard top question
i feel almost embarrassed to ask. so i'm purchasing a hard top, having lived with a soft top and half doors all my life. will half doors (and upper windows) mesh with a hard top, or will i have to buy full steel doors?
Thanks!!
95 hunter green YJ, rio grande
5spd 2.5L 4-cyl, >316k miles
(ARB Snorkel, K&N air filter, 6 KC lights, air restrictor removed, gas tank conversion, herculined, flat wiper conversion) 30" BFG's 1.5" shackle lift
Crotalus is offline
post #2 of 5 Old 10-28-2007, 07:12 PM
Douglas S.
chances are that you'll have to buy steel doors
1991 Land Cruiser HDJ81
Douglas S. is offline
post #3 of 5 Old 10-28-2007, 07:13 PM
joe's_yj
joe's_yj's Avatar
you need the rounded uppers for hard top or full doors
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #4 of 5 Old 10-28-2007, 07:14 PM
khalifa30
Depends on your upper doors. Most hard tops have rounded corners for the upper doors, while your soft uppers probably have a more angled corner. You can probably get aftermarket uppers with rounded corners.
khalifa30 is offline
post #5 of 5 Old 10-28-2007, 09:07 PM
tooblackdogs
tooblackdogs's Avatar
I struggled with this all last winter. The only real solution is full doors. There may be a fiberglass slider upper that could work but they are pricey. I used TJ uppers and the last peg sat inside the door. The first two pegs drop right in the holes. They actually sealed pretty good.
Don't tell my wife how much that really cost!
tooblackdogs is offline
hard top and hard doors question kkinsman YJ Wrangler Technical Forum 2 12-16-2009 02:59 PM
Hard top question hoytarcher TJ Wrangler Technical Forum 0 12-13-2009 08:43 PM
Hard Top Question and Lift question lawyerINaJEEP TJ Wrangler Technical Forum 1 08-12-2007 02:50 PM
Yet another hard top question Volley JK Wrangler Technical Forum 5 04-24-2007 08:09 AM
Hard Top Question? numnuts TJ Wrangler Technical Forum 4 11-14-2005 03:49 PM
