Hard Top Help!? - JeepForum.com
post #1 of 6 Old 08-31-2011, 07:07 PM Thread Starter
D-Rock86
Hard Top Help!?
I just bought a hard top and hard uppers yesterday for $300... this is my first jeep and I thought it was a pretty good deal? I never put one on before and realized that there is no way to attach it to the windshield frame! It looks like there used to be a plastic piece that ran along the inside of the hard top and attached with 6-8 screws. I looked at the back and found a Steel Horse sticker. Upon internet searching, it seems that this is not the most reputable brand of hard tops. I was wondering if anyone has ever used the qwick kits that have the two hard top latches that tension down and if you think that I could fabricate those onto it as a solution. I am running a 94 yj btw. Any other suggestions would be helpful... there is a large draft when driving and a lot of wind noise... so I know something needs to get fixed.
D-Rock86 is offline
post #2 of 6 Old 08-31-2011, 07:41 PM
JeepsOLot
I got the Kwik Kit, but, I only used the windshield latches. They work great, just don't know how the SH front lip looks, so, I don't know if it will work or not. I have the factory hardtop.
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #3 of 6 Old 09-01-2011, 10:26 AM Thread Starter
D-Rock86
anybody else ever have this issue?
D-Rock86 is offline
post #4 of 6 Old 09-06-2011, 12:00 PM
Que89YJ
The hardtop doesn't need to be attached at the windshield. Just run a strip of gasket on the top of the frame and install the hardtop. The body mounts are more thaen enough to hold it in place. There is a channel for the soft tops.
Que89YJ is offline
post #5 of 6 Old 09-06-2011, 04:16 PM
JeepsOLot
^^^ the only problem with that is, the front of the hard top will rub, squeak and such because, the windshield frame and top are not connected. You're right, the 8 bolts on the tub will keep it put, but, wind and rain can get in between the hardtop and windshield frame, force the top up, and make noise and get you wet as well.
Jerry
post #6 of 6 Old 09-06-2011, 06:52 PM
patnewk76
That's how ours was when we got it. Just using the bolts in the back to hold it down. Did some research and found out there used to be a strip of metal that was used to attach the hardtop to the windshield w/some rubber seal between. PO used duct tape which he said worked great. Forgot to mention needing ears plus....WOW!
91 YJ "Tonka" 4.0/ax15, stock/stock axles,
99 WJ 4.0 work in progress
patnewk76 is offline
Striker from full hard doors appears too big for hard half door? LEOinFL YJ Wrangler Technical Forum 1 05-24-2010 10:31 AM
Hard Top - Hard Doors Improvised Rattle solving thread bparsel YJ Wrangler Technical Forum 7 07-22-2009 08:23 PM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 03:57 PM
hard half doors/sliding windows/hard top tomthbomb YJ Wrangler Technical Forum 7 07-13-2007 08:42 PM
Who Sells Hard Door Inserts that match the Hard Top gtospeeding TJ Wrangler Technical Forum 7 05-06-2007 11:15 AM
