Quantcast Hard to Steer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hard to Steer
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 04-11-2005, 02:57 PM   #1
Imperial
Hard to Steer
1991 2.5L yj. Riding down the road one day nothing unusual, needed to make a turn and noticed that it took much more effort to turn the wheel. It seems there are small spots when turning that it becomes easier but in all the jeep turns as if it doesn't have power steering. Checked the fluid good, checked while running and the fluid is circulating, also seems to be good tension on serpintine belt... any ideas
Thanks
-Zach
Imperial is offline   Reply With Quote
Old 04-11-2005, 03:03 PM   #2
LandRover
Jack the front end off the ground and with the engine running, have someone cycle through the steering, lock to lock, while you're looking at the belt/pump/hoses for anything weird. I never found my leak until I finally did this. The hoses get pressrized more and more as you turn tighter, so make sure you're going lock to lock.
Could also be the stabalizer, if you have a dinged up rod in that thing or something... might not be power steering related at all.
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Maxxis Bighorn 32's
LandRover is offline   Reply With Quote
Old 04-11-2005, 07:59 PM   #3
Imperial
will do thank you.
Old 04-12-2005, 09:04 AM   #4
Wif
This might seem a dumb answer .. but it isn't stuck in 4x4 for some reason ..
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline   Reply With Quote
Old 04-12-2005, 10:39 AM   #5
Imperial
it's not stuck in 4x4, but i did have to do the mod where the front axle is locked (the vaccum system did not work so i welded the collar to the axles). The front axle runs through a differential so it should not cause a problem. I've had this done for a good 1000 miles never had a problem.
Old 04-12-2005, 10:59 AM   #6
RCHavok797
Check your steering shaft for any signs of rust along the joints. When mine developed rust along the joints I had spots where the steering wheel got a lot tougher to turn.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline   Reply With Quote
Glock Forum
