Hard starting - Page 2 - JeepForum.com
post #16 of 29 Old 06-06-2013, 06:09 PM
Que89YJ
do the fuel pressure test.you absolutely cannot tell anything about the fuel system without it.also check your fault codes.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 29 Old 06-06-2013, 06:28 PM Thread Starter
ellisfl09
Hard start
Ok I will do the fuel pressure test. Most likely it will be next week due to work, but the fault codes I had we're the 12,33,55 so no information given there. That was off of the cell light vice a code reader. Thanks again
ellisfl09 is offline
post #18 of 29 Old 06-06-2013, 08:07 PM
Que89YJ
they read the same codes. that is good. keep in mind that the obd1 codes don't always tell you when a sensor is bad. if it fails in range it will not blow a code.
Fault codes:
No Start:
Que89YJ is offline
post #19 of 29 Old 06-11-2013, 02:35 PM Thread Starter
ellisfl09
Hard start
Ok I just finished with the pressure test
She ran right at 29-30
When I pulled off the vacuum line she went to about 39
When I shut down the engine it dropped down to 0 before I could even look at the gauge
I assume fuel is leaking past injectors and I need new ones does this sound right.
Thanks for all of the help
post #20 of 29 Old 06-11-2013, 06:12 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Que89YJ should check in if he can but I would think the fuel pressure regulator is shot.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #21 of 29 Old 06-11-2013, 06:22 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
With the engine running the fuel pressure should be ~ 31psi. If you pull the vacuum line on the FPR the pressure should jump to ~39psi.
If it doesn't the FPR is NG. If it does check the vacuum source for the FPR.
post #22 of 29 Old 06-11-2013, 06:42 PM Thread Starter
ellisfl09
That's exactly what it does 30 at idle and when I pull the vacuume line it goes to 39 also brand new regulator. After shutting off engine pressure drops to zero
post #23 of 29 Old 06-11-2013, 07:11 PM
Siva283
You most likely have a bad check valve in the pump. Leaky I jesters when totally shot should drop steadily and take a min or two at least. The check valve in the pump will lose pressure instantly.
Ask me how I know...
Siva283 is offline
post #24 of 29 Old 06-11-2013, 08:45 PM
Que89YJ
it could be a bad check valve or injector. you need to find the soft hose anywhere on the return line and pinch it off. hook up the pressure guage amd jumper pins 30 & 87 together on the relay socket for the fuel pump for 3d seconds. if the pressure bleeds off then its a bad injector. if it doesn't then the fuel pump is bad.
Fault codes:
No Start:
Que89YJ is offline
post #25 of 29 Old 06-12-2013, 03:55 AM Thread Starter
ellisfl09
I just replaced the fuel pump. Ill pinch off the return but I am unsure what you mean with the relay, could you explain more please
Thanks
post #26 of 29 Old 06-12-2013, 04:47 AM
Que89YJ
if you just replaced the pump then you have a bad injector you need to pull the rail and see what injector its leaking. if you have the money it could be a reason to upgrade and replace all the injectors.
the relay thing I was talking about is jumpering the relay. if you pull the fuel pump relay from its socket and look at the side of the relay there is a numbered drawing of the relay socket. you can use a little wire and jumper pins 30 to 87 in the socket and the fuel pump will run. outer makes it much easier to troubleshoot the fuel system.
Fault codes:
No Start:
Que89YJ is offline
post #27 of 29 Old 06-12-2013, 01:10 PM Thread Starter
ellisfl09
Ok so based on my symptoms. It is a bad injector? Just want to double check. If so what injectors does everyone recommend? If I have the rail out I figure I may as well do all 4 of them
Again just to be sure cause I don't want to just spend money on parts
New parts: fuel pump, regulator
At idle 30psi
With vac line pulled 39 psi
After shutting off 0 psi within a few seconds
Thanks for all of the help again.
post #28 of 29 Old 06-12-2013, 01:22 PM
Que89YJ
yes it's a bad injector. get new of rings when you replace. a little oil will help them slide in easier.
Fault codes:
No Start:
Que89YJ is offline
post #29 of 29 Old 06-12-2013, 01:35 PM Thread Starter
ellisfl09
Ok sounds good. I replaced injectors on my 7.3 diesel never on a gas motor.
Do I need an injector puller for this
What injectors do you recommend
