Quantcast hard to start when she sits for a day - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > hard to start when she sits for a day
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 01-04-2008, 11:06 PM   #1
hepcat75
88 jeep YJ
weber carb was the only thing done to it for performance.
Anyway I bought this from my dad and it idleled like crap and found out about that nutter bypass and did it and it idles and revs great and even starts without giving it any gas untill it sits for awhile.
My main problem is when it sits for a day it takes a while to start like there is no fuel in the carb like it drains out or something. I can spray carb cleaner and she will fire right up then die when the starting fluid runs out.
I know there is no fuel pressure regulator on it and don't know if this could cause my problem but need ideas because i want to start driving it since I have had it for a little over a year( havn't put it in my name yet ) and it is time to put some miles on her.
Any thoughts
Raymond
hepcat75 is offline   Reply With Quote
Old 01-05-2008, 08:07 AM   #2
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
With the mechanical fuel pump, there's no need for a fuel regulator, it's only pumping 3-5 psi anyway.
A few things to check, Evap connections and your fuel filter. Obviously the fuel is not sitting in the carb after long periods, meaning it's draining back or evaping.
1st the fuel filter and return line. The fuel filter must be the 1 line in, two out kind. pump.. -filter= carb and return line. The two out, must be on the carb side, not the pump side. Also, the carb line must be the lower one, return line on top, reason being, this bleeds off the exess pressure back to the tank. If you have em flipped, (carb feed on bottom) the fuel will slowly leak back into the tank overnight. Also the filter MUST be at least as high as the connection at the carb, if it's lower, the bowl will drain back. (Hence the ugly steel hard lines holding the fuel lines up over your calve cover)
Check the evap system, make sure all hoses are tight and connected. (underneath windhield washer resivior) if one is disconnected it'll slowly evap the fuel from the carb overnight disipating it into the air. You won't smell it because of the charcoal inthe canister.
Richmond88yj is offline   Reply With Quote
Glock Forum
