Hard start after Scuba Jeepin' - JeepForum.com
post #1 of 7 Old 07-03-2009, 01:14 AM Thread Starter
YJake
The title says it all. I went Scuba Jeepin' and now I have a hesitant start. I hear a grinding noise and a second or two later it starts. Sometimes I have to try it once or twice for it to start up, but always after a second or two of grinding. The grinding isen't the noise of the engine turning over, it's like a really fast sound almost like a wood saw. After a second or two of that the engine turns over once and the engine starts right up just fine. I"m just worried.
What may I have messed up? (Oh, I ran over a few pine trees too)
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #2 of 7 Old 07-03-2009, 02:55 AM
humbert810
Sounds like the starter solenoid kicking in and out. The wood saw sound sounds liek the starter gear not grabbing the flywheel?
RED 1995 Wrangler YJ DD
Front and Rear custom bumpers
4" RC Susp. Lift
33x12.50x15 Firestone Destination MT's
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
humbert810 is offline
post #3 of 7 Old 07-03-2009, 06:10 AM
YJames90
YJames90's Avatar
I had the same exact problem after going through 2 feet of water last week. That noise sounded like metal teeth grinding.
It would start but grinded first.
I dont know how it fixed itself but it stopped after I stalled while wheeling on a very steep hill and restarted. Maybe the water drained out?
Try blowing some compressed air into the starter to dry/clean it out
My 2.5 to 4.3 swap thread
YJames90 is offline
post #4 of 7 Old 07-03-2009, 06:23 AM
tjmdr
Try the compressed air as jamesx2 said. If it doesn't fix it, you will probably have to take the starter off and clean it. Hope the air takes care of it.
tjmdr is offline
post #5 of 7 Old 07-03-2009, 08:16 AM
Fenix85182
Fenix85182's Avatar
I like this idea--should be easy enough to replicate.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #6 of 7 Old 07-03-2009, 09:10 PM Thread Starter
YJake
Thanks guys! Took it into some clean(er) water today and it must have got some dirt out because it starts much better now.
/l , [____],
()_) ()_)==@=)_)
YJake is offline
post #7 of 7 Old 07-03-2009, 10:11 PM
dodger889
You might want to pull the starter and regrease the bendix gear and hinge.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Why not a SCUBA Tank for tire inflation? medcop JK Wrangler Technical Forum 40 08-01-2013 01:49 AM
94 YJ 2.5 Cold Hard start now No Start Problem UNLIMITLESS YJ Wrangler Technical Forum 8 10-28-2009 04:53 PM
Co2 vs Scuba tank performance? ghost183 YJ Wrangler Technical Forum 8 03-31-2009 11:09 PM
Scuba tank? Gif38 YJ Wrangler Technical Forum 10 07-17-2007 04:07 PM
Scuba tank to fill tires? chris06 TJ Wrangler Technical Forum 10 08-23-2004 11:30 AM
