The choke plate should have a small space. I just ran mine about 5 minutes ago. When it cools down, I'll tell ya what my space is when the choke is set.
I usually tap my gas a pinch, just so ever slightly, sets the choke and gives a squirt. Do you have any vacuum leaks? Did you seal off the port under neath that goes to the choke? If not you'll have a vacuum leak. How about the float level? If set too high, the gas will empty over night, possible flood condition and no fuel in the bowl for intial startup. What size carb is it...1.08? What size jets?
If it does it only first thing in the morning, or several hours after it cools. Don't start it, look down the carb and tap the gas, is it squirting fuel?
