Quantcast Is it hard to install a Weber? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Is it hard to install a Weber?
Old 02-11-2007, 04:35 PM   #1
ElvisV04290
My Weber comes tomorrow(was going to be here on Friday but was set back one business day). I have a heated garage and a 24pack in fridge, ready to get to work. I just wanted a heads up on how long it takes to install and if it comes with good directions; Or anything I should look out for from you that have installed one. I bought mine from Carbs Unlimited at www.carburetion.com. I can't wait to play hockey with my old carter.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com
Weber 32/36 Install -> http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/
Early YJ Club Member #37
For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite
ElvisV04290 is offline   Reply With Quote
Old 02-11-2007, 05:14 PM   #2
biblicone
I did mine myself out in the cold, in the dark, and parallel parked in the street. I just planned it out in my head while looking at diagrams, repair manual and the engine itself. If you have a new one, it should probably have pretty good instructions. I bought a used one that had some different install instructions. If you take your time - it shouldnt take longer than a few hours.
biblicone is offline   Reply With Quote
Old 02-11-2007, 05:48 PM   #3
mrmustang
MAACO owner
mrmustang's Avatar
The only issues I had with my installation was my lack of reading comprehension in regards to the directions. Follow them to the letter and you'll be up and running in less time than it took to watch the Superbowl highlights..........
Bill S.
mrmustang is offline   Reply With Quote
Old 02-11-2007, 08:37 PM   #4
themonkeyman
1987 YJ Wrangler
You should use this thread to doa write-up on it, I'm sure a lot of people would like to see a comprehensive write-up (myself included.)
themonkeyman is offline   Reply With Quote
Old 02-11-2007, 11:46 PM   #5
ElvisV04290
Good idea. I did not see one in the write up area. If all goes well I'll have one up within 24 hours.
Weber 32/36 Install -> http://www.jeepforum.com/forum/showthread.php?t=382309
Old 02-12-2007, 10:30 AM   #6
t_rexx70
It's A Piece Of Cake And You Are Going To Love It After Having Run That Carter. It's Like A New Vehicle After The Install. Just Make Sure You Label All Your Lines So You Know Where They Come From And Where They Need To Go. You Can Lose Alot Of Your Old Vacuum Lines Which Is A Great Thing. I Did The Nutter Bypass Which Depending On What Motor You Have...also Made A Big Difference. Oh And Make Sure You Use The Supplied Locktight Where Applicable. I Had Some Throttle Linkage Come Loose While Driving Down The Interstate. Not Cool...apparently I Did Not Put Enough Locktight.
[COLOR="Blue"][FONT="Arial Black"][SIZE="4"]88YJ 4.2l, weber 32/36, nuttered, 4" super lift, TFI, stock 30 and 35 pos axles alloy 4.10's, lockrights, posilocked, 33 X 12.50 Mudbrutes[/SIZE][/FONT][/COLOR]
t_rexx70 is offline   Reply With Quote
Old 02-12-2007, 12:51 PM   #7
ElvisV04290
Chanes are I will do a bypass but I need to make sure that the Weber will pass emissions here in Illinois first. I got the kit that hooks up to the stock air cleaner so I can keep the emissions crud in place. There is a guy on here that has a Weber done the bypass, has no emissions stuff and still passed. If the Weber passes I'll do the Nutter and test it again. Thanks for the advice on the locktight
Glock Forum
