Hard getting back in 1st. - JeepForum.com
post #1 of 7 Old 03-05-2002, 12:16 AM Thread Starter
CaSea4Me
I was out for a nice sunny Sunday S.CA drive last weekend and as the temp. up so did the difficulty getting back into 1st. after a full stop. What do you think? Please tell me it's not the slave cyl. taking a dump
'04 TJ Sport, 5spd (what else?), 4" Currie lift w/ Antirock, Teraflex 4:1, ARB's (F&R), MT Baja Claws 33x12.50 and so on :)
CaSea4Me is offline
post #2 of 7 Old 03-05-2002, 02:19 AM
sadler207j
I have the same problem with my 94 yj 2.5l, difficult to get into first at a stand still. I usually hold in the clutch and go into 4th and then it will go right into 1st. I would also like to know what the problem is problem.
sadler207j is offline
post #3 of 7 Old 03-05-2002, 07:35 AM
jeepken
The problem i have encounter with wrangler 2.5L,it's difficulty to shifted to third gear while on driving.what is a actual problem?I need a transmission gear diagram to verifiy...anybody can help
jeepken is offline
post #4 of 7 Old 03-05-2002, 10:28 AM
damonejeep
I resently had all of the same issues with my tranny. Sorry to say but I had to have it basically rebuilt.
First, check your clutch fluid and tranny fluid levels. Top off if needed. If this does not help, all I can tell you is to take it to a tranny specialist that you trust and hold onto your hats, it could be expensive.
Hopefully I am completely wrong and there is nothing wrong.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #5 of 7 Old 03-05-2002, 07:26 PM
jeepdog
The problem you are having is that the pilot bearing (in some cases it's called a pilot bushing) is eather out or going out. It is a relatively easy fix. You do need to get into the clutch to do this though.
94 YJ 33s 4.5 rubicon express extream duty and lots of scars.
Keep the rubber side down!!!!
jeepdog is offline
post #6 of 7 Old 03-05-2002, 08:42 PM Thread Starter
CaSea4Me
Hey Dog..
Thanks for your info.
Pilot bearing? Doesn't that mate up with tranny spline? It didn't realize things went in or out of it once the spline was inserted after re-mating of trans. 2 engine. Am I confused?
Thomas
CaSea4Me is offline
post #7 of 7 Old 03-06-2002, 12:02 PM
89 YJ
It could be the syncromesh going out. Its a common thing in transmissions and they wear quick. It could also be the pilot bearing. Mine does this and I am not into costly repairs to have it just go back out in a few months. Try double clutching! It works great for me. When going into 1st gear and it dont wanna go, let clutch back out and push back in and shift. It will get the syncros ligned up again and it should fall into gear. Takes just a second and seems to work on any stickshift with this problem. Oh and it works for the 3rd gear prob too.
89 YJ Islander, AC,PS, 10 inch lift, 32 BFG MT's, sway quick disconnect, rear track bar quick disconnect, 400 watt 12 speaker cd player for tunes,8000lb warn 8274 with 150 ft cable, and a high lift jack.. Lockers, 35's, webber carb and jacobs ignition comming soon.
89 YJ is offline
Hard top back window ghanasjeep TJ Wrangler Technical Forum 2 07-30-2008 02:31 PM
Hard top to soft top and back whippo YJ Wrangler Technical Forum 10 08-06-2007 11:42 PM
Hard Top Back Glass ccbiggz TJ Wrangler Technical Forum 14 11-07-2006 12:04 PM
Hard top, back window ? YCP4x4 TJ Wrangler Technical Forum 4 10-18-2005 10:44 AM
Hard Top Back Window ascola TJ Wrangler Technical Forum 3 08-04-2004 03:31 PM
