is it hard to do a new exhaust? - JeepForum.com
post #1 of 13 Old 03-30-2010, 07:45 PM Thread Starter
celticluck713
so if i buy a new catback system is it hard to install? anything difficult i need to do or just like bolt stuff on
celticluck713 is offline
post #2 of 13 Old 03-30-2010, 08:19 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Cat back is easy. Cut out old, bolt new on. Don't bother trying to save old hardware. Just cut everything off and bolt in new.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 13 Old 03-30-2010, 08:20 PM
Mark455SD
1961 CJ5
Only problem I had was the rear track bar was in the way. Easy job, I just had to take the track bar off
Mark455SD is offline
post #4 of 13 Old 03-30-2010, 08:28 PM
4LarXedo4
make sure you look over your current exhaust system now, i ended up replacing the front pipe as well as the cat due to so much rust and rot.
4LarXedo4 is offline
post #5 of 13 Old 04-01-2010, 01:00 PM
drew2000
drew2000's Avatar
Just a note: many of the performance cat backs use a larger outlet pipe than stock, which can bump into things (the body, shocks, lift shackles, etc.). I will be ditching my cat back and returning to stock someday so I can return to the original stock diameter...Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #6 of 13 Old 04-01-2010, 01:04 PM
EABiker
The front pipe to cat bolts can be tricky since the skid plate limits access to the rear of the flange. It may also help to remove the rear shock if it gets in your way.
EABiker is offline
post #7 of 13 Old 04-01-2010, 01:06 PM
Bane7962
I'd buy or borrow a dremel. Saved me a lot of frustration to be able to just cut the old **** instead of fighting with the hardware.
Working with cars is a little like a really awesome date: you start out expecting this to be something simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought.
When my Jeep stops making strange noises, I become concerned. That usually means I have to go back and find whatever fell off.
Bane7962 is offline
post #8 of 13 Old 04-01-2010, 01:18 PM
ufatbastehd
Mine was simple
I replaced everything from the motor to the rear tail pipe.
Cut every thing off.
Like Mark455SD said the re track bar got in the way so I cut it off.
Good luck
ufatbastehd is offline
post #9 of 13 Old 04-01-2010, 01:42 PM
mfalik
mfalik's Avatar
I would suggest an angle grinder with cut-off blade, instead of a dremel. It will go quicker and there will be less of a chance of breaking cut-off wheels.
Just my
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
post #10 of 13 Old 04-01-2010, 03:01 PM
ZeroGravity
I would recommend a sawzall as well. Most cutoff disks won't make it all the way through.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #11 of 13 Old 04-01-2010, 03:36 PM
bill8bud
I did mine last week and the sawzall blew my dremel away.
bill8bud is offline
post #12 of 13 Old 04-01-2010, 04:24 PM
T-Mack
yeah not hard me and my brother in-law did it in an afternoon just cut off and replace with new
T-Mack is offline
post #13 of 13 Old 04-01-2010, 05:37 PM
bill8bud
just don't cut off to much....lol
bill8bud is offline
Hard Top - Hard Doors Improvised Rattle solving thread bparsel YJ Wrangler Technical Forum 7 07-22-2009 07:23 PM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 02:57 PM
Upgraded head, but changed Exhaust Manifold so how do I get an exhaust system now? jeepdude1987 YJ Wrangler Technical Forum 2 02-18-2009 11:54 PM
Rock Hard JK Bumper + Flowmaster exhaust Baotchi JK Wrangler Technical Forum 14 03-31-2008 10:50 AM
Clayton hard arm upgrade... exhaust, sway bar help atomicmaggot TJ Wrangler Technical Forum 0 03-11-2008 07:41 PM
