Hard Cranking - JeepForum.com
post #1 of 10 Old 11-03-2011, 11:39 AM Thread Starter
JOKER007
Hard Cranking
Hi guys new to the site here and want to give all a big thanks for all the info out there. But I have ran across a problem that I need help on.
My problem is my jeep when cranking performs like it is out of time or has a weak starter once started she runs and idels very well no other problems.
Here is what I have done so far:
1988 Wrangler 4.2 Standard
Oil and Filter change
Nutter Bypass ( Ran a seperate Ground )
Team Rush Upgrade
Plugs and wires
MC 2150 carb ( Air Filter )
Fuel Filter
New Battery
New Starter ( Ran a seperate Ground to Starter )
Checked for vac leaks and repaired
Set timing 10 BTDC Tried at 1600 RPM and at 650 (Had Vac line off and plugged while setting) Ended up going 12 BTDC to smooth things out.
Ran Compression Check on cylinders
1-110
2-130
3-115
4-125
5-125
6-135
Help Please
JOKER007 is offline
post #2 of 10 Old 11-03-2011, 11:50 AM
pasinbuy
Not really sure what your problem is. Does she start? Is it just a little loud, normal?
What are the symptoms exactly.
pasinbuy is offline
post #3 of 10 Old 11-03-2011, 12:00 PM Thread Starter
JOKER007
Yes she has never failed to start and runs out real good, it is just when you turn the key the engine turns over as if it is out of time or has a week starter.
JOKER007 is offline
post #4 of 10 Old 11-03-2011, 12:08 PM
AmmitOsiris
Same ith mine I m trying figure tthis out I pump the gas because its carb'd I wanna know what the problem is please someone have a diagnosis.
AmmitOsiris is offline
post #5 of 10 Old 11-04-2011, 12:35 PM Thread Starter
JOKER007
Bump
JOKER007 is offline
post #6 of 10 Old 11-04-2011, 12:57 PM
dancytron
I didn't see new battery cables on the list.
dancytron is offline
post #7 of 10 Old 11-04-2011, 01:25 PM
Que89YJ
X2. You need to load test the battery at the parts store and check/clean all the cables from the battery to the chasis, starter, and alternator .
Que89YJ is offline
post #8 of 10 Old 11-04-2011, 05:03 PM Thread Starter
JOKER007
Sory I have replaced the cabels, Load tested the new bat held 11 volts under full load even tuck the bat out of the truck to double check, could the distributor be out just enough to make hard cranking but let her run good after started?
JOKER007 is offline
post #9 of 10 Old 11-05-2011, 06:00 AM
Que89YJ
11 is low. What is the reading at the battery with the engine running. Sounds like the alternator might not be putting out enough juice.
Que89YJ is offline
post #10 of 10 Old 11-05-2011, 07:09 AM
dodger889
Without the engine running 11 is not low under load test. Now below 9 is low under a full load test. This is how you test a battery.
What is the voltage before and after the load test. Without the engine running.
Sound like your timing is out and if I remember it should be 7* Not 10* at idle.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Cranking hard, misfiring, low RPM when slowing down, and throwing TPS code. jeep2012 TJ Wrangler Technical Forum 3 09-01-2010 03:07 PM
no cranking PrinothPro YJ Wrangler Technical Forum 8 05-19-2010 11:45 AM
please help, not cranking jimdager YJ Wrangler Technical Forum 4 04-14-2009 09:52 AM
97 tj tries to stall after cranking wncjeeper TJ Wrangler Technical Forum 3 01-30-2008 07:53 PM
Engine not cranking Keith YJ Wrangler Technical Forum 5 08-13-2001 11:15 PM
