Hankook 31" Tires on '95 YJ w/ No Lift.. - JeepForum.com
post #1 of 4 Old 06-30-2001, 12:27 AM Thread Starter
Scoob
Well, I had the Sahara checked out and the guy told me it was in better condition than any Jeep he has seen...other than it neede an alignment. So, I am now a proud owner of my 1st Jeep!
I have a couple of questions I thought I would throw out here for anyone that feels like responding:
1. Any opinion on Hankook Tires?
2. Will 31x10.5x15 tires fit on a jeep
with no lift?
3. If it needs a lift, how high, and what
kind of lift?
I am supposed to have them put on first thing in the morning. !Gracias! in advance...
'95 YJ Sahara (Champagne) / 31x10.5 Hankook / 2.5" ProComp lift / Mesa, AZ
Scoob is offline
post #2 of 4 Old 06-30-2001, 01:26 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Hankook - Good
31" tire on stock Jeep - Fit w/ some rubbing on full flex
If your springs are sagged out (common), you can have them re-arched to allow the tires to fit properly ..
Laters!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 4 Old 06-30-2001, 07:22 PM
smithbuiltYJ
I had 31x10.5x15's put on stock 15x7 rims. the only problem I had was rubbing the springs on a hard turn - a couple washers on the steering stops fixed this. also aftermarket rims with wider backspacing would prevent this also. 1 problem i did not expect was with the bigger spare on the tailgate - my hardtop hatch would not clear the 31. (i now have a swing-out tire carrier on order). I also have a '95 YJ, and have since put on a 2" lift.
happy trails,
Marshall
'95 YJ, "Toy Story", some mods done, some mods on the way.
smithbuiltYJ is offline
post #4 of 4 Old 07-01-2001, 06:03 PM
osburn
osburn's Avatar
Personally, I think 30" tires are about as far as you should go on a YJ with no lift. You'll rub the springs if you keep the stock offset, which is better than getting them out away from the springs with a different offset and rubbing the flares and wearing them tell tale curves into the flares. No matter what offset you run, you'll be contacting the fenders when you off road. 30" tires are what you want. If you don't absolutely need tires right now, save your money for a 2" lift or something.
Matt Osburn
Score 1032
osburn is offline
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
Another wheel and tire size question? (Will 32" tires fit with 2" lift) TJ's02TJ TJ Wrangler Technical Forum 12 10-30-2009 08:43 PM
tires (32" tires with 2" lift and 3 speed auto w/ 3.07 gears) libertynewyork TJ Wrangler Technical Forum 15 10-20-2009 10:03 AM
Unlimited Rubicon , 3" Black Diamond lift , 35" Hankook tires , Commander Hulk wheels RedRockJK JK Wrangler Technical Forum 67 03-25-2007 10:39 PM
315/70/17 (34.5" tall) Hankook RT03 tires on 17x7.5 wheels ShockTherapy JK Wrangler Technical Forum 7 01-05-2007 05:30 PM
