handling question - JeepForum.com
post #1 of 3 Old 07-19-2001, 08:57 PM Thread Starter
goodwrench67
handling question
I have an older "88" YJ and it follows every roll or swail in the road. If you look at the front view of the jeep the front shackles lean a little, do the bushings wear out and how hard is it to replace them? Would that cause the handling problem? any help is appreciated.
goodwrench67 is offline
post #2 of 3 Old 07-19-2001, 10:17 PM
osburn
osburn's Avatar
Replacing the bushings is a good idea and not too difficult. But to diagnose your problem, I'd say just tighten them up first. Generally, the symptoms you describe are caused by tires.
Matt Osburn
Score 1032
osburn is offline
post #3 of 3 Old 07-20-2001, 08:27 PM Thread Starter
goodwrench67
Thanks, yeah, it needs alot of work including tires.
Getting the best handling on a TJ heyitsme TJ Wrangler Technical Forum 30 11-27-2008 03:25 PM
Handling Question tcass JK Wrangler Technical Forum 5 03-01-2008 05:18 AM
highway handling question for everyone Jeepin'J TJ Wrangler Technical Forum 3 05-01-2006 02:46 PM
After lift handling affects question. Grape Ape YJ Wrangler Technical Forum 7 01-04-2006 07:10 PM
Handling in the wet Mike17112 TJ Wrangler Technical Forum 14 10-11-2002 09:28 AM
