Hand throttle cable routing - JeepForum.com
post #1 of 91 Old 11-17-2008, 05:30 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Okay, I put a bicycle shifter lever on my gear shifter this weekend to start my hand throttle mod. I measured the amount of pull available from the bicycle shift lever which was about 1-1/2"+ inches, and then I measured the throttle linkage movement (where the cruise control is supposed to hookup) and that is about 1-1/2" inches also, so I should be able to access 100% of the throttle plate movement. The lever has a friction screw adjustment, so I can also have some "Kentucky Kruise Kontrol" too!
I plan on running the cable down along the shifter, through the shift boot(s) and along the top of the tranny and up the firewall to end up at the throttle plate.
Is this how most everybody else does theirs? Or do most folks run it inside the tub & through the firewall?
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 91 Old 11-17-2008, 05:32 PM
Matt_vs_YJ
That's exactly how I routed mine, only I used a bicycle brake lever so that it wouldn't get stuck at the wrong time.
Matt_vs_YJ is offline
post #3 of 91 Old 11-17-2008, 05:34 PM
Brandon_YJ
1987 YJ Wrangler
I've never done this mod, and don't need to (TF999 ), however 0 I would suggest making it as clean as possible and run it down through the boot and into the engine compartment.
You can go to any bike shop and ask for cable and housing (they usually buy in bulk) and it's pretty cheap. Or go to nashbar.com and order it from there.
At least that is how I'd do it.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #4 of 91 Old 11-17-2008, 05:35 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Umm, which "how"? You mean like the way I planned on doing mine? I listed both ways.
The friction adjustment on mine will allow for it to easily return with the OE throttle return spring, or hold it in place if I tighten up the little screw.
Mean Max is offline
post #5 of 91 Old 11-17-2008, 05:36 PM
Brandon_YJ
1987 YJ Wrangler
Oh, and remember that the cable will stretch (up to 1/4") over time... but with this application you are looking at about a year (at least) before it can stretch that much.
Just thought I'd drop that info so later on down the road you'd know to make an adjustment if it gets to not acting like it used to.
in a (text only)
post #6 of 91 Old 11-17-2008, 05:37 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
A buddy of mine owns a bike shop. I went to his shop today, and they have 6' foot long cables with an end already attached & bulk housing material for cheap.
Mean Max is offline
post #7 of 91 Old 11-17-2008, 05:38 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I have those little screw adjuster thingies for each end.
Mean Max is offline
post #8 of 91 Old 11-17-2008, 05:40 PM
Brandon_YJ
1987 YJ Wrangler
Sounds like you got what you need then.
I used to do ALOT of biking (XC, road, and commuting)... butfor my knees gave way (not from the biking) and I'm not able to do it any more... plus I'm fat now.
But I think running it down the shifter and under the tub would make for a clean application.
in a (text only)
post #9 of 91 Old 11-17-2008, 05:49 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I used to ride/race offroad motorcyles about 10 years ago, but not anymore and I'm fat now too.
Thanks for the input! That settles it, it's going down through the shift boot.
Mean Max is offline
post #10 of 91 Old 11-17-2008, 05:59 PM
Brandon_YJ
1987 YJ Wrangler
Woah dude, I hope you're talking about the YJ there!
in a (text only)
post #11 of 91 Old 11-17-2008, 06:39 PM
Matt_vs_YJ
oops... yeah, the first way. Down through the shifter boot and up along the firewall to the top of the engine.
post #12 of 91 Old 11-17-2008, 07:33 PM
bigsquat
of all the mods i did i like the hand throttle the most. I ran mine in the boot and out the bottom of the boot flange under the carpet on the inside of the jeep and then thru the firewall, right next to the posi-loc cable
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #13 of 91 Old 11-17-2008, 09:33 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I wish I could get mine to go down to my boot........
Mean Max is offline
post #14 of 91 Old 11-18-2008, 06:02 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Installed the hand throttle today. I haven't quit grinning & playing with it since!
I talking about the hand throttle Brandon!!!
Mean Max is offline
post #15 of 91 Old 11-18-2008, 06:06 PM
Brandon_YJ
1987 YJ Wrangler
Of course you are
in a (text only)
ox cable routing? yeppo575 YJ Wrangler Technical Forum 0 04-12-2009 09:06 PM
posi lok cable routing damian H YJ Wrangler Technical Forum 2 07-31-2008 10:03 PM
Anyone use NAPA throttle boat throttle cable for homemade posilock? EABiker YJ Wrangler Technical Forum 0 05-15-2007 05:31 AM
E-Brake Cable Routing YJ-Mike YJ Wrangler Technical Forum 3 03-23-2007 08:49 AM
Cb in dash and cable routing Tx_Yj YJ Wrangler Technical Forum 11 02-27-2006 03:29 PM
