Hand Throttle - JeepForum.com
post #1 of 9 Old 03-19-2009, 10:05 AM Thread Starter
Tradewinds
Hand Throttle
On my CJ I had a hand throttle that attached to the shifter allowing me to work the clutch and brake without having to worry about the gas pedal when in rough country and crawling over/around things. It had a trip lever that would disconnect instantaly if needed. Does anyone know if someone still makes them, I cannot find any info on them?
Tradewinds is offline
post #2 of 9 Old 03-19-2009, 10:16 AM
muddy93
1987 FSJ Wagoneer
most that I have seen are home made, and use a bycycle brake levar. it is spring loaded, so it goes back to idle as soon as you let go of it.
personally, for the one I made, I used a byclyle shifter levar, with an adjustable tension knob. with the knob backed off, it works just like the brake levar style. however, with the tension knob tightened down, I can set the rpm, and it will hold it(usefull when winching, or running OBA)
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 9 Old 03-19-2009, 10:44 AM
timatoe
timatoe's Avatar
Rubicon Express makes one ~ $30.
timatoe is offline
post #4 of 9 Old 03-19-2009, 10:58 AM
crb577
rubicon express and teraflex both make them. I just installed my rubicon express this past weekend.
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #5 of 9 Old 03-19-2009, 11:26 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here's how I did mine. It's homemade.
http://www.jeepforum.com/forum/f12/hand-throttle-cable-routing-633530/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 9 Old 03-19-2009, 11:33 AM Thread Starter
Tradewinds
Thank you for the info on the throttle control. Looks like making one would be more fun than buying it. I apprecaite the info from each of you.
post #7 of 9 Old 03-19-2009, 11:35 AM
mr_dees
mr_dees is offline
post #8 of 9 Old 03-19-2009, 11:36 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
I'm into mine for under $20, including the thumb shifter I grabbed off of a bicycle my neighbor had in the trash pile!
Recycling rocks!
Max
Mean Max is offline
post #9 of 9 Old 03-19-2009, 12:45 PM
lonestar_yj
I just made one for my jeep. I had a factory cruise control cable from another jeep and a bicycle brake lever. The cruise cable works perfectly, it attaches to the stock bracket on the motor.
93 wrangler sahara, 4" lift, 1" shackles, 33x12.5 maxis buckshots on crager rims, hm front,back bumper,towbar, hand throttle
lonestar_yj is offline
hand throttle chutta TJ Wrangler Technical Forum 4 02-19-2007 09:22 AM
Hand throttle.... ragweed13 TJ Wrangler Technical Forum 7 04-08-2006 07:14 AM
Hand Throttle zaq123 TJ Wrangler Technical Forum 45 03-28-2006 03:39 PM
hand throttle??? jipjip YJ Wrangler Technical Forum 24 03-16-2006 11:26 PM
Hand Throttle Q's SpilledMilk TJ Wrangler Technical Forum 21 12-10-2002 07:52 AM
