On my CJ I had a hand throttle that attached to the shifter allowing me to work the clutch and brake without having to worry about the gas pedal when in rough country and crawling over/around things. It had a trip lever that would disconnect instantaly if needed. Does anyone know if someone still makes them, I cannot find any info on them?
most that I have seen are home made, and use a bycycle brake levar. it is spring loaded, so it goes back to idle as soon as you let go of it.
personally, for the one I made, I used a byclyle shifter levar, with an adjustable tension knob. with the knob backed off, it works just like the brake levar style. however, with the tension knob tightened down, I can set the rpm, and it will hold it(usefull when winching, or running OBA)
I just made one for my jeep. I had a factory cruise control cable from another jeep and a bicycle brake lever. The cruise cable works perfectly, it attaches to the stock bracket on the motor.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
