Halo Headlight installation - Page 3 - JeepForum.com
post #31 of 37 Old 12-22-2009, 05:19 AM Thread Starter
Sissy Heep
sealing them
I put the rtv sealer around the edge of the glass where it meets the housing.
the Halo part is a seperate leds not intergraged in the h4 bulb
91 YJ 4.0
75 FJ40
76 FJ40
99 LX470
87 Honda Rebel
96 Yamaha Virago
Sissy Heep is offline
post #32 of 37 Old 12-22-2009, 06:04 AM Thread Starter
Sissy Heep
These halo's say 80/85 watt on the h4 bulb housing
91 YJ 4.0
75 FJ40
76 FJ40
99 LX470
87 Honda Rebel
96 Yamaha Virago
post #33 of 37 Old 12-22-2009, 06:40 AM Thread Starter
Sissy Heep
Halo healight picture
Ok guys here is the picture of the back of the halo headlights
the reg harness headlight plugs into the H4 bulb
4 extra halo wires are 2 small red and 2 small white
Hook the 2 whites together and ground to screw shown
Hook the 2 red wires together and add some length of red wire and extend down to parking light harness and tap into the red and blue wire on the parking light harness (for a 91 yj colored wires) not sure if it is the same for all yjs wire color. Just find the hot wire for the parking lights make sure it is not the hot wire for the turnsignals, other wise your halo will blink with the turnsignals.
And thats should do it.
I dont think the h4 bulbs are replacable on this unit, they seam to be sealed in, but for 16 dollars for the 2 headlight what do you expect.
The H4 bulbs are 80/85 watt. Dont forget to seal the rim with RTV before installation the day before. Rim meaning where the glass meets the plastic housing. Just to make sure they stay dry. Also had to bend the tabs at the back of the headlight housing just a bit to get them to seat properly. Not much, but a tiny bit. You can see the big tabs upper and lower on the picture
91 YJ 4.0
75 FJ40
76 FJ40
99 LX470
87 Honda Rebel
96 Yamaha Virago
post #34 of 37 Old 12-22-2009, 06:40 PM
GRN_BEAST95
no their not perminant. you just gotta get that ig black sealer off the back. i kinda twisted and pulled and from there u can get the bulb out. Did u upgrade your harness??? Also can i get a pic of where the splice for the hot wire is?
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline
post #35 of 37 Old 04-17-2013, 02:36 PM
crackedcornish
wait, you revived a 4 year old thread in the YJ section just so you could post a link to a place that doesn't even offer parts that fit a YJ??.....you spammer
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #36 of 37 Old 04-17-2013, 10:04 PM
Carlos14
Bingo
He pulled this one back from 2007
http://www.jeepforum.com/forum/f9/an...42/index2.html
Those are his only 2 posts.
Luck Favours The Prepared
Carlos14 is offline
post #37 of 37 Old 01-07-2014, 07:52 PM
jeepmonkey06
So how do you get the lens of the housing on h4. Isn't is sealed with a heat resistant silicone?
jeepmonkey06 is offline
Halo Headlight Installation Issue iJeeper YJ Wrangler Technical Forum 16 11-24-2009 10:05 PM
Headlight retaining ring installation? Deadhorse TJ Wrangler Technical Forum 3 07-02-2009 03:48 PM
angel eye HALO headlights JeepDrivr93 YJ Wrangler Technical Forum 10 09-28-2004 01:16 PM
Halo / Demon lights? u4ea TJ Wrangler Technical Forum 0 09-05-2003 04:45 AM
H4 Halo Conversion Complete. Drew99 TJ Wrangler Technical Forum 12 06-23-2003 11:38 PM
