Half doors to full steel doors - '94 body, '88 doors - JeepForum.com
post #1 of 9 Old 04-21-2009, 11:50 AM Thread Starter
xponce
Hey everyone!
I have a 1994 Wrangler YJ "S". I bought it used and my daughter uses it now to go to school until I can afford a new car for her. Anyway, I have a pair of full steel doors that I bought used that I believe came off a '88 model (doors are stamped with 6-88 inside under the inner panel). Right now I have half doors that are squared at top (which I will be selling with the old top, if someone is interested). I want to buy a top that I can use with the full doors but I am having problems lining up the full steel doors on the frame. The striker does not coincide with the latch (about 1 inch off). Are the doors adjustable in anyway either at the striker, hinges, or latch enough to make them fit?? Will changing the striker or hinges to a different year possibly work? I may have read the date wrong stamped on the door, it may, but doubt it, have said 6-86 (door has been painted inside and out since then). Will that make a difference? Any help will be appreciated.
xponce is offline
post #2 of 9 Old 04-21-2009, 11:55 AM
cmsurfer
Yes, the hinges can be adjusted on the door. I had to make some adjustments when I got my full doors. The striker can also be adjusted if needed.
cmsurfer is offline
post #3 of 9 Old 04-21-2009, 12:18 PM
TheNewbie
They should fit with some adjustment.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #4 of 9 Old 04-21-2009, 12:42 PM
muddy93
1987 FSJ Wagoneer
yes, they should fit.
for adjustment, you can adjust both hinges on the door, and you can also adjust the body side of the lower door hinge(however, you can not adjust the body side of the upper door hinge.)
to adjust these, just loosen the bolts a little, move the door, then tighten the bolts.
to adjust the striker, you just loosen it(counter clockwise, like a big bolt), move it, and tighten.
I've got 198? CJ doors on my 93 YJ, and after a little bit of adjustment, they fit just fine.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #5 of 9 Old 04-21-2009, 01:17 PM Thread Starter
xponce
Thanks guys for the help. That really sets me straight on that. I was getting a little worried. I'll have the pics up when I finish.
xponce is offline
post #6 of 9 Old 02-20-2010, 12:31 PM
SpideYJeep
CJ doors on YJ
When you say adjustment, did you have to do any drilling or just loosen-jiggle-squeez? Damn, sounds like a jello commercial LOL
SpideYJeep is offline
post #7 of 9 Old 02-20-2010, 02:52 PM
domdan69
Loosen, jiggle, squeeze and be ready to adjust windshield also to get all good and tight.
93 YJ I6 4.0 custom welded aluminum front fender, herculined , 33" 12.50 15x8 BDS 2" suspension, M.O.R.E. Boomerang shackles, Teraflex disco's, Flattened and hacked out wells, electric fan to replace stock fan.WARNx8000i,high-lift jack,relocated mirrors
domdan69 is offline
post #8 of 9 Old 02-20-2010, 02:55 PM
domdan69
http://www.jeepforum.com/forum/f12/c...tapics-830099/
domdan69 is offline
post #9 of 9 Old 02-20-2010, 03:29 PM
burnout189
loosen the door hinges at the door, and loosen the striker on the jeep. i usually put a piece of cardboard under the door and close it, and then tighten up the hinges. the cardboard will allow a gap so that the door doesnt hit at the bottom.
BARNHART'S AUTO REPAIR
burnout189 is offline
going from full steel doors to half doors on a 03 Kip03TJ TJ Wrangler Technical Forum 11 02-07-2010 07:44 PM
Newer TJ Half Steel Doors?....or Bestop 2 Piece Soft Doors sweetguardian00 TJ Wrangler Technical Forum 16 02-14-2008 07:21 PM
switching out full steel doors for soft doors. monkeychrist TJ Wrangler Technical Forum 8 07-19-2007 10:41 PM
Steel Half doors or soft doors? SINISTER1957 TJ Wrangler Technical Forum 1 04-26-2006 04:01 AM
Half Doors or Full Steel???? newjeepguy2 TJ Wrangler Technical Forum 9 11-29-2002 03:55 PM
