Half door mirror on full steel door?
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | |
Anyone know if you can use a mirror from a half door on a full steel door? Looks like it mounts the same. Got a set of full doors that's missing the mirror on the driver's side. Was thinking of pulling the one off my half doors and using it. Can worry about buying a replacement in the Spring then.
His : 1992 YJ (Almighty 4 banger) Hers: 2004 WJ Columbia Edition (4.7HO) Black Jeep Society - Black Jeep Club V2.0 #37 - Merry Wacko Jeep Club #37 - Metalhead Jeep Club #37 - 2.5L Low Output Jeep Club #37
#2 | |
FWIW, they ARE they same on the TJ's, and I'd think if they are the same style mirror, they should fit the same.
but, on my '91 and '95 YJ's, the hard door mirrors were smaller and a different style, and mounted to the door-skin upper, rather than the hinge (like on the half door mirrors on my '93) so,? ![]() if they both mount to the hinge, they should work fine and be interchangeable. ![]()
Don't mind me, I'm just another FNG around here...
#3 | |
#4 | ||
first one, I applied a little pressure, and SNAP! luckily, though, it was the torx driver that busted... bought a new hardened one and the rest came out just fine. Good luck!
#5 | |
Hell, I might even grab the Windex and go clean the windows ![]()
#6 | ||
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
