half door adjustment - JeepForum.com
post #1 of 2 Old 09-03-2011, 06:24 PM Thread Starter
tylerthebike
So I got some new half doors. The drivers side fits fine, but the pass sticks out a little more at the latch. Everything seems to be fine but the top by the corner of the hard top is hitting before it fully latches. It gets to the "safe" position, but not fully. Is there a way to move the latch closer to the outside of the door? I tried search but couldnt find anything about in/out only up/down. Thanks for the help.
tylerthebike is offline
post #2 of 2 Old 09-03-2011, 06:47 PM
JamesHasler
There are 4 screws on the "bolt" on the body side (not door side) of the latch. If you loosen the 4 screws, you can move it up/down and left/right. That might work for you! (I don't know if you can move the part on the door.)
James
JamesHasler is offline
adjustment , door , half , hard , YJ
half door rubber seal issues (2nd sent of half doors) sail78385 TJ Wrangler Technical Forum 0 06-19-2010 02:59 PM
Does a half door plus an upper half = a hard door? Grinner JK Wrangler Technical Forum 2 04-10-2010 11:51 PM
Will TJ half door panels fit on a YJ half door? shinerm02 YJ Wrangler Technical Forum 0 07-02-2009 10:41 PM
Mirrors adjustment on JT half doors abeginner TJ Wrangler Technical Forum 7 05-08-2008 10:35 AM
Where to purchase half upper half door absentiabanish TJ Wrangler Technical Forum 3 04-11-2005 09:26 AM
