Quantcast haha it never ends. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > haha it never ends.
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 09-24-2004, 02:05 PM   #1
Bobbywolf
haha it never ends.
Ok, some of you know that I just recently replaced my clutch master cylinder after it was giving me grief for the past while. It fixed the problem, and I had a nice solid clutch pedal, for 4 days...
Now today, I'm 90% sure I just blew out my slave cylinder. I was driving home from a friends, when my clutch pedal went from perfect, to non-existant in less than 5 mins. When I had master cyl problems before, it took several days for the clutch to get really bad, so I knew this time was different. I limped home using only 3rd gear, and popped the hood to check the clutch reservoir. Not a drop. I look underside and follow the line to the transmission case. No leaks whatsoever. It all must be inside the transmission where the slave is. Sucky.
I remember reading before on this forum that when someone replaced their master, the extra strain from the strong master, blew out the slave a week later. I'm pretty sure the same thing happened to me here. Why me?
Bobbywolf is offline   Reply With Quote
Old 09-24-2004, 02:27 PM   #2
UPnOVER
Yup and you'll have to pull the tranny to get it out....Not that hard but will take some time.
I get older and they stay the same age.
[COLOR=red]RED JEEP #6[/COLOR]
91' YJ, D30 EZ, F8.8 locked & 410's, BDS4+" lift, 35" BFG's on 15x8 RC, 8,000lb Ramsey, etc. www. rock-nutz.com
UPnOVER is offline   Reply With Quote
Old 09-24-2004, 02:27 PM   #3
sequel
I figure it's best to do the whole clutch at the same time. Try www.dialaclutch.com for LUK. That's what I put in and i really like it.
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline   Reply With Quote
Old 09-24-2004, 03:19 PM   #4
Bobbywolf
So do parts places sell a kit that includes the clutch and slave cyl? What kind of $ am I looking at?
Old 09-24-2004, 05:36 PM   #5
hmk_21
it's a yellow jeep thing.
joking. altho ive been thru 2 slaves, and 3 master in the course of a year and a half.
most frustrating job ever.. altho i have the removal of the tranny down to an art now.
89 Yellow YJ Islander 4.2L *decal free*
[url]http://www.cardomain.com/id/89yj_kmh[/url]
hmk_21 is offline   Reply With Quote
Old 09-24-2004, 08:51 PM   #6
Why J?
i had the same problems that everyone keeps talking about with masters and slace cylinders so i got sick of it and i replaced everything, i mean everything including that piece of sh&^ rubber connecting tube. i think that after time the heat and the hydrolic pressure wears it out and if causes stress on the master and the slave. I put in a metal one that i made from some brake line. haven't had a problem since.
Why J? is offline   Reply With Quote
Old 09-24-2004, 09:58 PM   #7
pirate_looks
clutch issues
after 3 dealer slave cylinders, 2 master cylinders and the new hose, it finally works... this is what i learned though..
1) bleeder line... make sure that it is somewhat restrained in the small oval hole it comes out of,. the vibration causes this line to walk, then loosen up over time.. i used a drum brake adjustment cover thing.. the little oval rubber part..
2) purchased a new clutch an pressure plate.. the fingers on the clutch where the bearing contacts it.. a few of the fingers stuck out further than the others.. this i believe caused the throwout bearing to vibrate, then the little pin that holds the thing in comes apart..
just replace all of it..
the good news is, mcleod clutches is making a replacement slave cylinder for the jeep wranglers with the 4 cyl.. talk to red, hes the owner.. I talked to him about this a while ago, but he is takin his time with the production. perhaps some calls about this would help..
good luck all..
dave
pirate_looks is offline   Reply With Quote
Old 09-24-2004, 10:11 PM   #8
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
I feel for you bobby! but at least yours lasted a few days. my slave went the same night i replaced my master. i picked up my clutch set from dialaclutch for about 170. everything you need.
pirate, what's so special about mcleod clutches? haven't heard of them before.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote
Old 09-25-2004, 12:04 AM   #9
Bobbywolf
Ah it was you then Same night, wow that sucks.
I was thinking about replacing these things myself, but I have a feeling that I will need the use of a lift (that I don't have). My jeep is lifted already, so maby I can just get under there with a hydrolic jack (that I DO have), and use that to drop the tranny, while leaving the jeep standing on 4 wheels. It will be alot of crawling around, but is it doable? I'd love to save the money and learn doing it myself. I also have fairly handy friends.
Old 09-25-2004, 04:02 AM   #10
randy33876
I feel your pain! I also have been down this dark and endless road they call jeep clutches!All I can say is replace everything at the same time and beg forgivness from the clutch gods for any past sins you may have comitted.
randy33876 is offline   Reply With Quote
Old 09-25-2004, 11:32 AM   #11
sentinal02
sentinal02's Avatar
i just did it on mine a few months ago. only used the floor jack. they do sell an attachment for them that is supposed to transform it into a tranny jack. one tip i learned after i was done is to replace two of the bolts with some long threaded rods before pulling the tranny. they'll act as guides to help hold one end of the tranny up and will allow you to line up the input shaft with the splines better. it's not an easy job, but it's doable. one the tranny is down it's simple to change the clutch itself.
Old 09-25-2004, 12:00 PM   #12
Tshark299
1987 YJ Wrangler
Jeeze, with all these slave cylinder threads I read, I cringe everytime I have to shift!
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Old 09-25-2004, 03:16 PM   #13
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
yep my slave is almost gone too, every month or so i have to bleed the system again!!! its getting old, and I think its been a while so its probably time to replace the clutch anyway.
O and you guys know about the 95 external slave cylinder swap?? theres a ton of posts on that at www.pirate4x4.com
I Hate Rainbow Trout
FunkSkunk is offline   Reply With Quote
Glock Forum
