Had a minor fire now its hit or miss if she starts. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Had a minor fire now its hit or miss if she starts.
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-21-2015, 05:32 PM   #1
Swampwalker3
1987 YJ Wrangler
Had some aw4 tranny wires I weren't using fall onto the o2 sensor and started a small fire due to the plastic. Once I put it out the jeep would start for a minute or so and shut off, had to wait and she'd turn over again. I repeated this hour process until I got "home".
At first I thought it was the o2 sensor since that's where the fire was but after reading I find that it wouldn't cause this issue and try unplugging it to see if the attitude changed. It didn't.
Moved onto the CPS since they are tempermental with over heating and that it's only a few inches away from the 02 sensor, maybe I fried it.
Replaced it and ran it for about 5 minutes while I cleaned up the area. Jumped in and took off. 50 feet down the road she died. Same issue. Finally got it back out of the road. Turned it back on let it idle for a bit-no dying, moved it back and forth-no dying, gunned it forward and no dying. Put it in Park and she immediately died..
The issues never came up until the very small fire at the o2 sensor. Ran great..
Zane Neher
88 YJ. H.O. 4.0L/AW4/twin sticked d300/1 tons/38.5s.
Swampwalker3 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 12:47 PM   #2
bruinjeeper
bruinjeeper's Avatar
Did the fire happen on the wires? Did the fire get into the actual harness? any melting? Are all the pins present?
Do you have any pics?
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
bruinjeeper is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 12:49 PM   #3
bruinjeeper
Could the flames have gotten to any higher points? I.e sensors at the TB?
Unread 05-24-2015, 03:10 PM   #4
Swampwalker3
1987 YJ Wrangler
I don't see any other issues caused by the fire. The wires were to the aw4 that weren't being used that I reckon I didn't secure. They fell on to the o2 sensor and the fire was very minor melting the plastic on the wires. The engine harness was unhurt.
Unread 05-24-2015, 09:38 PM   #5
Que89YJ
It sounds like you are shorting out something. Does it start right up after it dies?
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 05-24-2015, 10:13 PM   #6
Swampwalker3
1987 YJ Wrangler
Nope. If I wait a few minutes it'll start right up. I could isolate the bare wires though from the aw4. I don't believe they're getting any power but could be a start.
Zane Neher
Unread 05-25-2015, 02:46 AM   #7
Que89YJ
But you have a few minutes. Good, check for fuel and spark.
Unread 05-25-2015, 11:20 AM   #8
Swampwalker3
1987 YJ Wrangler
She gets fuel. putting some fuel in the intake was a sure sign that I'm not getting spark. Before changing the cps I unplugged it after a no start and plugged it back in and she fired right up.
Im going to isolate those bare wires and see what happens.
Zane Neher
Unread 05-26-2015, 03:54 PM   #9
Swampwalker3
1987 YJ Wrangler
Thanks bud, turns out that's what it was.
Zane Neher
Unread 05-26-2015, 04:13 PM   #10
Que89YJ
It's running again?
Unread 05-27-2015, 10:00 PM   #11
Swampwalker3
1987 YJ Wrangler
Yessir.
Zane Neher
