Is h4 headlights the best? - Page 3 - JeepForum.com
post #31 of 92 Old 02-17-2014, 08:14 AM
zstamp19
Tom95YJ where did you get your lights and how did you retro fit them? You may have posted it and I just missed it reading through all this. Did you have to replace any wiring with that swap or were you able to run the stock wiring? Just trying to figure out how much of a pain it is going to be to replace my lights.
Thanks
zstamp19 is offline
post #32 of 92 Old 02-17-2014, 09:45 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by zstamp19
Tom95YJ where did you get your lights and how did you retro fit them? You may have posted it and I just missed it reading through all this. Did you have to replace any wiring with that swap or were you able to run the stock wiring? Just trying to figure out how much of a pain it is going to be to replace my lights. Thanks
I bought them from froleichsuspensiontechnology .com. To be honest I won't ever order from him again. I have not received them and it's been over 2 months. People who ordered in November are just getting theirs.
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is online now
post #33 of 92 Old 02-17-2014, 10:02 AM
zstamp19
That is nuts. I found them on Ebay and all that but I hate buying stuff from there. Did you buy a retro fit kit or make it yourself?
zstamp19 is offline
post #34 of 92 Old 02-17-2014, 10:59 AM
Tom95YJ
Tom95YJ's Avatar
I bought them pre made but have not got them yet I may build a set for my YJ
'99 XJ Black Betty
post #35 of 92 Old 02-17-2014, 01:33 PM
zstamp19
That sucks well I may look into some different things all i know is I need to do something because I can't hardly see at night with what is currently running. I may try and adjust these some seems like they just not be angled right maybe from the lift the previous owner did
zstamp19 is offline
post #36 of 92 Old 02-17-2014, 07:23 PM
panaceabeachbum
hope to try out my xenon H4 soon, left QAUDRATEC on the 5th, as soon as FedEx remembers were they have put them I will know how they compare
panaceabeachbum is offline
post #37 of 92 Old 02-17-2014, 07:26 PM
zstamp19
Let me know how those look I'm interested in anything that works and looks good
zstamp19 is offline
post #38 of 92 Old 02-17-2014, 08:24 PM
jdubsjeep
There is only 1 set I would run, here is the info. Cibie H4 headlamps 200mm 142mm (7.9” 5.5”) http://www.danielsternlighting.com/p...ducts.html#Buy
Anyone who knows lighting will know this link. You pay more for the headlamps (because they are better), and get the Narva or Osram bulbs. You cannot beat E code lens. Check out how many other Jeepers use these!
jdubsjeep is offline
post #39 of 92 Old 02-17-2014, 10:14 PM
djwrangler
1997 XJ Cherokee
Originally Posted by jdubsjeep View Post
There is only 1 set I would run, here is the info. Cibie H4 headlamps 200mm 142mm (7.9” 5.5&rdquo http://www.danielsternlighting.com/p...ducts.html#Buy
^ this. If you're looking for a great upgrade that actually improves night time driving, this is the way to go. I run the Cibies with the Narva 55/100 bulbs and an upgraded relay harness. I found this setup to be better than the Trucklite LEDs I was running before. Sharper beam pattern and cleaner spread of light.
Well worth the cost. I did everything for less than $250.
djwrangler is offline
post #40 of 92 Old 02-18-2014, 07:49 AM
zstamp19
What all do I need to get to update the relays? I saw they had some on there but it doesn't really tell you which ones you need. But thanks for link I will be ordering some of these soon
zstamp19 is offline
post #41 of 92 Old 02-18-2014, 09:38 PM
jdubsjeep
Email Daniel, he will walk you through it and get you all set up. You will not believe what you were missing. The pattern on the wall is amazing to see the beams cut off so clean and go up on the right. Be sure to mention that you are in the US because European lights go up to the left because they drive on the left side of the road. Once you adjust your lights you will know exactly what I am saying.
post #42 of 92 Old 02-19-2014, 07:58 PM
panaceabeachbum
I received my H4 housings and bulbs from Quadratec today. They are brighter and I counted 7 more rows of peanuts on high beam than with the sealed beam halogen lamps. That said I would have been better off to purchase a single 1280 lumen led driving light and wire it into the high beam circuit. Would have saved 60 bucks and been able to see just as far.
As mentioned many times in various threads here the reflectors in most of the H4 kits for the YJ are less than optimal, the light is brighter and I can see further but there are lots of peaks and folds in the beam, lots of dim triangles.
post #43 of 92 Old 02-20-2014, 06:34 AM
zstamp19
Who is Daniel? I haven't been on here long enough to know people's names yet. Thanks for the info guys this is the most informative site!
zstamp19 is offline
post #44 of 92 Old 02-20-2014, 07:10 AM
kingcat400
Could you link to the lights you bought. I think I know why the beam is messed up. But want to verify.
kingcat400 is offline
post #45 of 92 Old 02-20-2014, 07:14 AM
kingcat400
http://www.danielsternlighting.com/p.../products.html
Headlights going out JFox YJ Wrangler Technical Forum 2 09-19-2009 06:37 AM
headlights come on... and go out huckster YJ Wrangler Technical Forum 8 12-09-2008 08:22 PM
Headlights go on, radio goes off. Headlights off, radio back on gary1 YJ Wrangler Technical Forum 10 10-29-2008 10:07 PM
IPF headlights kurt'smoneypit TJ Wrangler Technical Forum 48 03-16-2007 10:12 PM
Headlights sxmp YJ Wrangler Technical Forum 17 01-13-2005 10:24 PM
