Is h4 headlights the best? - JeepForum.com
post #1 of 92 Old 02-01-2010, 09:21 AM Thread Starter
jagarcia82
1987 YJ Wrangler
Was just curious what type of headlights are the brightest for YJ's? Is h4's the best? if so what type have you guys tried out? Or what do you recommend. Also is there addition wiring needed or simply plug and play?
Also anyone having trouble with searches now? I keep getting an error when I try now?
jagarcia82 is offline
post #2 of 92 Old 02-01-2010, 09:40 AM
jaminb
THere are H4 conversion kits out there for the YJ. i personally have the IPF H4 head light housings and the IPF phat boy bulbs, they are the best headlight i have ever seen, i personally like them better than HID's. With those bulbs i did not need new wiring, how ever i did melt one of the crappy plastic connectors on the stock harness, so i just pulled the connector apart and sodder crimped on new connector to each wire, that way the heat can disapate. Havent had an issue now for over a year.
jaminb is offline
post #3 of 92 Old 02-01-2010, 09:59 AM
itsnotmyjeep
itsnotmyjeep's Avatar
Im planning on getting these.
I have purchased from them before and they are good quality.
Susquehanna MotorSports - Auto Performance Product
What wattage you get will depend on if you need to update the wiring or not.
this space for rent
itsnotmyjeep is offline
post #4 of 92 Old 02-01-2010, 12:01 PM
trw
2011 JK Wrangler
after I installed a heavy duty wiring harness to eliminate the voltage drop, I used IPF H4 housings with Silvania Silverstar Ultra H4 bulbs, and I had more light than most higher end luxury sedans and SUVs, and the ricers cant believe my lights outshine their "cool blue" drop ins
The Silverstars aren't the best bulbs to use either, I got them because I was in a bind.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #5 of 92 Old 02-01-2010, 12:08 PM
YJake
I got some cheap H4 housings from ebay and they're much better than stock, but I'd still rather have some Hella E-code housings or IPF for better light distribution.
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #6 of 92 Old 02-01-2010, 12:56 PM
92 Green YJ
92 Green YJ's Avatar
I got some Pilot H4 conversion housings on my YJ and put Silverstar H4 bulbs in them. While they are brighter and better than stock, personally I am saving up to get an HID kit to put in the housings instead. If you want bright light you can't beat HIDs. I installed and HID conversion kit on my Hayabusa and I absolutely love them! I like them so much I want to put a set in my YJ and my tow rig
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #7 of 92 Old 02-01-2010, 01:13 PM Thread Starter
jagarcia82
1987 YJ Wrangler
So whats the difference in h4 and HID?
post #8 of 92 Old 02-01-2010, 02:33 PM
jaminb
HID stands for high intesity discharge. It uses a gas to create the light. Not amp it like a normal filiment bulb does. Personally I have yet to see a head light that is made to run an HID bulb (projectors are needed to run HIDs) that looks good on a jeep. If you want good light out put with out having to do alot of wiring just get a set of H4 housings and some good H4 bulbs (ipf,Hellas, delta,) something like that. Stay away from off brand lights. There is nothing out there to regualte the output of lights except if there dot or not. Some companys will say there optical out put is super high or that the actual wattage is super high but that doesn't always mean the lights will be bright (ask me how I know)
jaminb is offline
post #9 of 92 Old 02-01-2010, 04:36 PM
540i
Check out the Autopal ones on ebay, they are nice I've had 2 sets and you can't beat the price, metal back glass front and come with bulbs.
200mm H6054 H4 EURO CONVERSION HEADLIGHTS KIT : eBay Motors (item 330392142866 end time Feb-02-10 21:23:37 PST)
540i is offline
post #10 of 92 Old 11-18-2013, 01:48 AM
zippoguy
Hi all, great thread, could someone tell me what kind of a wiring harness is recommended to properly upgrade?
zippoguy is offline
post #11 of 92 Old 11-18-2013, 07:59 AM
crackedcornish
has anybody here ponied up the big $$ for a set of these LED's yet?
http://www.jeepforum.com/forum/f43/t...roved-1750410/
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #12 of 92 Old 11-18-2013, 08:36 AM
Carlos14
An H4 is simply the style of connector being used to tie into the wiring harness. When you out HIDs in a jeep you must use an H4 connector to plug it in.
What you mean is what is the difference between HALOGEN and HID, as you can get both with the h4 connectors.
As to the differences, halogen lights are the stock/common lights in most vehicle on the roads. HIDs use a xenon gas inside the bulb which draws a lot more powers putting out a lot more light, but if not properly aimed, it's useless glare.
I'm personally a fan of the LED headlights however Trucklite is out of my price range, so I'm building my own.
Luck Favours The Prepared
Carlos14 is offline
post #13 of 92 Old 11-18-2013, 09:24 AM
beemerkid
My room mate has a round pair for his cj, and they are quite good. Brighter than my h4 conversion with stock wiring and 100watt high beam bulbs. Also more even light distribution. About on par with my rigid d2's. If you love light, they're pretty sweet.
beemerkid is offline
post #14 of 92 Old 11-18-2013, 10:58 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Trucklite LEDs are bright , I personally ordered a set of bi Xeon hid retro fitted h4 housings using FXR projector, gatlin gun shroud ,and a 4300k temp bulb I will not see them until January/February since I am on a waiting list.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 92 Old 11-18-2013, 11:44 AM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
HID lights use much LESS power when compared to conventional or halogen. Usually less than half.
HID lights are comparable to street lights as they are a subtype of modern arc lights. There are metal salts as well as different gases, not just xenon. There are mercury vapor, metal halide ect. Depends on which bulb chosen.
When the arc is initiated, the metal salts evaporate forming plasma which increases the lights intensity and reduces the power demand.
HID's are a generic term like Kleenex. They are everywhere. Sports arenas streetlights, movie sets. The light has the ability to be very natural.
I will switch to LED when they can match my HID's. Getting better, but not yet.
And last, all lights need to be aimed.
GET OFF MY LAWN!
Chrisnvegas is online now
Headlights going out JFox YJ Wrangler Technical Forum 2 09-19-2009 06:37 AM
headlights come on... and go out huckster YJ Wrangler Technical Forum 8 12-09-2008 08:22 PM
Headlights go on, radio goes off. Headlights off, radio back on gary1 YJ Wrangler Technical Forum 10 10-29-2008 10:07 PM
IPF headlights kurt'smoneypit TJ Wrangler Technical Forum 48 03-16-2007 10:12 PM
Headlights sxmp YJ Wrangler Technical Forum 17 01-13-2005 10:24 PM
