Guys running Howell Fuel Injection - JeepForum.com
post #1 of 4 Old 01-24-2009, 06:13 PM Thread Starter
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
For those of you running the Howell system on your Jeeps, are you still using the stock ignition module? I've been having starting issues and I believe it might be the source of my problems. If you're running something different what is it?
'87 Wrangler, Stroked with a few other toys...
Matt87YJ is offline
post #2 of 4 Old 01-24-2009, 07:53 PM
yellow2kgt
Stock ignition module here. I did do the Team Rush upgrade. But other then that all stock and no problems.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #3 of 4 Old 01-24-2009, 11:09 PM
timatoe
timatoe's Avatar
I'm running a HEI, I know jbolty runs the HEI as well.
timatoe is offline
post #4 of 4 Old 01-24-2009, 11:15 PM
jbolty
jbolty's Avatar
that I do. got the kit from CRT performance.
jbolty is offline
Howell Fuel Injection help needed. kmj153 YJ Wrangler Technical Forum 17 09-06-2010 07:55 PM
howell fuel injection conversion basestealer12 YJ Wrangler Technical Forum 12 10-10-2009 09:47 PM
Howell fuel injection cableguy01960 YJ Wrangler Technical Forum 6 01-11-2009 11:04 PM
Howell Fuel Injection Conversion maximum729 YJ Wrangler Technical Forum 3 03-19-2008 05:52 PM
DUI Dist. and Howell Fuel Injection G8RH8R YJ Wrangler Technical Forum 1 04-11-2005 12:10 AM
