Gutless Stroker - JeepForum.com
 2Likes
post #1 of 25 Old 10-09-2017, 07:58 PM Thread Starter
youngjeepr
Gutless Stroker
For a little background I built the stroker 3 years ago then I bought a house and had my first kid so long story short I just got it up and running after some wiring issues.
I used a 4.0 block and connecting rods with a 4.2 crank,hesco rvob6 cam, hesco FPR, 30lb/hr injectors, a 62mm throttle body, 7120 port/polished head. I can?t for the life of me remember what pistons I went with.. but I know I ordered a set of KB944-60 but they didn?t work for some reason and my machine shop ordered a similar set that would. I also can?t remeber what valve springs I used but I talked to hesco and ordered what they recommended for there cam. When I built the motor I followed the medium buck 4.7 build sheet from this site but it has changed since I built my motor. http://www.jeep4.0performance.4mg.com/stroker.html
Now that you know what?s done to the motor here?s my problem..... it will fire right up but sounds really rough at idle and has no power. I checked for misifires and found that I can pull the spark plug wires or fuel injector plug on cylinders 3 and 4 without any change. Then I checked for spark and power to the injectors and I have both. Next I did a compression check on cyl. 3,4,5 and all were close to 180psi (cold).
I?m not sure if I need to maybe advance timing or maybe the injector timing is off but there is something definitely wrong. I have an air fuel gauge and it?s running around 14.5-15.5 with the FPR set at 47psi.
Hopefully you guys can help me get this figured out. I would really appreciate it!
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #2 of 25 Old 10-10-2017, 07:45 AM
gotswap
If you pull the plugs on the impacted cylinders and ground them, do you get spark? That would at least help determine if you have a spark or fuel issue
gotswap is offline
post #3 of 25 Old 10-10-2017, 08:31 AM
cyoos
There's always the possibility that your cam is one tooth off. It will start but it will run pretty rough. I have no idea how I know this, but...uhmmm...well, yeah...I do. LOL
4.6L/AX15/OME/1" booms in back/8.8-4.10-LSD/XJ D30 in work/32" Falken Wildpeak AT's
cyoos is offline
post #4 of 25 Old 10-10-2017, 09:01 AM
shaggyjim
shaggyjim's Avatar
You have power to the injectors but is the injector actually firing off?
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #5 of 25 Old 10-10-2017, 10:57 AM Thread Starter
youngjeepr
I just assumed they are firing. They are brand new injectors. I?ll put a stethoscope on them tonight and see if I can hear them fire.
post #6 of 25 Old 10-10-2017, 10:59 AM Thread Starter
youngjeepr
I have spark to the plugs and power to my injectors. My injectors are new so I assume they are firing but I?m going to double check tonight.
post #7 of 25 Old 10-10-2017, 11:02 AM Thread Starter
youngjeepr
Do you mean engine timing or ignition timing?
I degreed the cam when I put it in and double checked it before I closed everything up but that doesn?t mean I did it right haha if I don?t find anything else I will pull the motor back apart and check it again.
As for ignition timing I?ve set the distributor 1 tooth retarted and 1 tooth advanced of where it is now. But that was about a year ago so I?m going to check it again tonight.
post #8 of 25 Old 10-10-2017, 02:49 PM
shaggyjim
shaggyjim's Avatar
It might be just as easy to swap them to cylinders you know are running and see if the problems follow them. My first thought is that they corroded over in storage and wont open. My second thought and its a longshot is that if you have fuel and spark at the dead cylinders but the engine shows no change when they are deactivated I wonder if you wiped out some cam lobes from the long storage. Hopefully its just a timing issue.
Jim...
post #9 of 25 Old 10-10-2017, 03:20 PM Thread Starter
youngjeepr
I?ll swap the injectors and see what happens. I don?t think I have flattened cam lobes... the motor only has maybe an hour of run time on top of the 30 min cam breakin.. but who knows maybe I did. I?ll throw my dial indicator on a push rod and check the lift. Any idea how to check duration?
post #10 of 25 Old 10-10-2017, 03:36 PM
shaggyjim
shaggyjim's Avatar
Like I said it was an outside chance with the cam. Did it run well when you did the cam brake in? Also when did you do the brake in? When it was built? Dumb question but you did set the timing with a timing light right?
Jim...
post #11 of 25 Old 10-10-2017, 04:27 PM
cyoos
Disregard what I said about the cam. I was trying to think and read at the same time and it didn't work out too well. After rereading it, it sounds like @gotswap and @shaggyjim are on the right track.
cyoos is offline
post #12 of 25 Old 10-10-2017, 04:46 PM Thread Starter
youngjeepr
I did the break in earlier this year probably around March. I had a pretty bad leak in my fuel tank so I didn?t run it longer than the 30 min cam break in time at 2k RPM. So I?m not sure how it ran at idle. It sounds smooth at above 1300RPM ish. I?ll take a video of it when I get time in the next day or 2.
Ignition timing is set by the ECM on the 4.0 and can?t be mechanically adjusted unless you cut the mounting point off the distributor housing. I havnt cut it off yet or checked the timing with my timing light. Just lined up the rotor in the dist. With number 1 plug while number 1 cyl. was at TDC on the compression stroke.
I figured I would get it running decent then fine tune it by mechanically adjusting the timing if needed.
I?m going to double check my timing aswell tonight when I get home from work.
post #13 of 25 Old 10-10-2017, 07:06 PM
shaggyjim
shaggyjim's Avatar
Well how bout that. I learn something new everyday.
Jim...
post #14 of 25 Old 10-10-2017, 10:27 PM Thread Starter
youngjeepr
Well I didn?t get to the injectors tonight but I did check my timing. It was retarted pretty far so I moved it a tooth advanced but it wouldn?t start... Then I moved it a tooth back and it barely ran so I tried moving it back to the original spot and couldn?t find the sweet spot. So tomorrow after work I?ll put #1cyl at TDC and drop the dist. back in the right spot but this time I?ll cut the mounting point off so I can manually time the motor with a vacuum gauge.
post #15 of 25 Old 10-11-2017, 06:13 AM Thread Starter
youngjeepr
Well I just found out that indexing the dist. Doesn?t adjust ignition timing it only adjusts injector timing.
gotswap likes this.
