Quantcast Grinding in third gear, how much time do I have left - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Grinding in third gear, how much time do I have left
Truck-Lite's New LED Headlamp SeriesNEW! Poison Spyder RockBrawler BFH Bumpers!Poison Spyder BFH Rear Bumpers
Old 05-23-2009, 05:06 PM   #1
Mr-Rock
Mr-Rock's Avatar
My AX-15 started grind when shifting into third gear, I assume the synro's arre going. how much time to I have before ther rest start going?? Is there any thing I can do to "save" it for a while??
Thanks
'89, 4.2, NUTTERED, Team Rush, 4" lift, 1"BL, 1"MML, Flat belly skid, SYE, CV Driveshaft,
35 x 12.50s, XRC8, 150w KC's, Herculined, Tauras Elec Fan, Dual Batteries, 1" shackles & Soft Top for the summer, TJ flares.
Mr-Rock is offline   Reply With Quote
Old 05-23-2009, 05:19 PM   #2
Krochus
try replacing the existing fluid with SYNCROMESH
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline   Reply With Quote
Old 05-23-2009, 07:08 PM   #3
giggityjeeper
time for a fluid change, maybe your clutch is needing some fluid to...or maybe its the clutch not hte trans...mine grinds in 2nd and third and downshifting to 2nd and 1st or over 3 years now....still going storong change the oil 2 times per year
Started with some rust repairs ended in a SOA...
http://www.jeepforum.com/forum/f12/how-make-big-hole-your-jeep-1050879/
family roll bar swap/upgrade..
http://www.jeepforum.com/forum/f12/family-bar-swap-upgrade-1054753/
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline   Reply With Quote
Old 05-23-2009, 08:06 PM   #4
tippmann243
my trans ground going into 3rd for a bit.
it was my daily at the time and my other vehicle was down for the winter. i drove it for most of the winter i would sya 2-3 months. did fine, i just couldnt use 3rd gear at all.
89 blazer, L31/t56 28mpg.
blazer video, http://s29.photobucket.com/albums/c279/tippmann243/?action=view&current=1204091507-02.flv
1990 jeep, 4.2, 5speed.
tippmann243 is offline   Reply With Quote
Old 05-23-2009, 09:13 PM   #5
93jeepyj
I would try the syncromesh if your not already running it. If so double clutching takes the stress of the syncros and should keep it from grinding.
93jeepyj is offline   Reply With Quote
Old 05-23-2009, 09:42 PM   #6
mrclean
Thanks
It may work for a week, it may never fail, no way to tell. As others have said, change out the fluid. Synchromesh is a good substitute for the factory fill(cheaper too). You also may want to add a bottle of that Lucas Oil additive. Looks like a bottle of snot, but it may help a bit(quieted mine down, although a couple of bearings were going bad in mine, not synchros).
mrclean is offline   Reply With Quote
Old 05-23-2009, 10:50 PM   #7
Mr-Rock
Mr-Rock's Avatar
Do I use 75-90w gear lube? i thought I read somewhere that now you are supposed to use 10w30, Is this true???
Old 05-23-2009, 11:08 PM   #8
mrclean
Don't use either of those, you will accelerate the demise of your trans.
The stuff you want is called Synchromesh, Autozone carries it(others may also, but I know for sure AZ has it).
Redline also has a suitable substitute(MTL or MT90, can't remember which). But it is more expensive, and for me, harder to get, as there is no local Redline dealer.
Old 05-23-2009, 11:16 PM   #9
Krochus
as the poster above mentions use neither of those.
This is the magic bottle you're looking for. This stuff is simply amazing, I need to rebottle this stuff as "liquid ax15 rebuild kit" and sell it for $100 a quart
see this thread
http://www.jeepforum.com/forum/f12/penzoil-synchromesher-read-before-replacing-synchros-747237/?highlight=syncromesh
Old 05-23-2009, 11:47 PM   #10
Mr-Rock
Mr-Rock's Avatar
[QUOTE=Krochus;7278687]This is the magic bottle you're looking for. This stuff is simply amazing, I need to rebottle this stuff as "liquid ax15 rebuild kit" and sell it for $100 a quart
Ok, just got done reading thru that thread and in the morning I'm off to find some.
I'll let you know how it works for me.
Thanks to everyone!
Old 05-24-2009, 01:05 AM   #11
uglyoldbob
Not my thread, but a related question. If double-clutching and a fluid change to the aforementioned syncromesh doesn't solve grinding into third gear, then would the clutch/syncro's be worn? It works great and I plan on pulling the transmission when I have a spare vehicle.
I would say great things about the syncromesh, but just changing the fluid wasn't enough to prevent grinding in my case. I can't quite rule out wear of other components yet though.
Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life. - Terry Pratchett.
Please browse my photography Use 10percentftw to recieve 10% off purchases.
1995 XJ, 6.2L, 700r4, 3.55 gears, 2wd (Still being built)
1994 YJ, 4.0L HO, AX15, np231, 31" tires, hardtop, 3.07 gears, trailmaster lift (4.5"?)
uglyoldbob is offline   Reply With Quote
Glock Forum
