Grinding reverse - JeepForum.com
post #1 of 5 Old 06-03-2013, 08:33 PM Thread Starter
heyvern
Grinding reverse
My 95 AX15 grinds a bit when I shift to reverse. It does seem to do that a little bit less when warmed up, but it still does it. Is that normal?
Also the cap on the clutch fluid reservoir has no seal in it , just a vent hole. Am Iissing some kind of seal there?
heyvern is offline
post #2 of 5 Old 06-03-2013, 09:17 PM
idaholtby
Absolutely normal. AX-15s do not have a reverse synchro. Double clutch before throwing it into reverse and you will be fine.
Your master cylinder cap should seal and then act as a check valve.
idaholtby is offline
post #3 of 5 Old 06-04-2013, 06:14 AM
kahanabob
when starting i always shift into 2nd then into reverse......sometimes if i try reverse without shifting thru another gear first it will not even go into reverse i then shift into 2nd let out the clutch roll the jeep a couple of inches then goes right into reverse.
kahanabob is offline
post #4 of 5 Old 06-04-2013, 03:14 PM Thread Starter
heyvern
Thanks for the answers! I do approviate Just wanted to make sure it was nothing that I could fix.
heyvern is offline
post #5 of 5 Old 06-04-2013, 03:16 PM Thread Starter
heyvern
...um that should say " appreciate " ... I guess the IPod "fixed" it for me
heyvern is offline
