Grinding noise when clutch pedal pressed - JeepForum.com
post #1 of 2 Old 02-20-2009, 07:51 AM Thread Starter
fran87yj
1987 YJ Wrangler
I have a noise that sounds like metal grinding when I push on the clutch pedal to shift gears. When in gear and moving the noise stops. It only occurs when the pedal is pressed. I am not very familar with clutches or transmissions. I had a new clutch installed last year and it has been fine until now. Any ideas what could be the cause?
fran87yj is offline
post #2 of 2 Old 02-20-2009, 08:56 AM
Zer0
could be your throw-out bearing. I kno someone with a TJ that makes a grinding noise when idling with the unpressed.
But your gears shift fine I supposes?
Zer0 is offline
04 2.4L air leak when gas pedal is pressed SpriggZ TJ Wrangler Technical Forum 8 10-29-2016 11:37 AM
clutch pedal squeeks when pressed trav_k1234 TJ Wrangler Technical Forum 3 11-27-2008 06:43 PM
clicking noise when the gas pedal is pressed ... SOMETHING WRONG?! minileprechaun TJ Wrangler Technical Forum 10 02-09-2008 07:24 PM
Clutch pedal noise cbmadcow TJ Wrangler Technical Forum 4 09-20-2006 07:19 PM
Clutch pedal clicks when pressed FLMarine TJ Wrangler Technical Forum 11 03-17-2004 11:58 AM
