Grinding Gears - JeepForum.com
post #1 of 6 Old 02-26-2002, 07:07 PM Thread Starter
BrandonParvin
Grinding Gears
When i bought my jeep, 2nd gear was grinding. Now All gears are grinding. I have had my jeep for just a little over a year. Also when i come to a stop, sometimes i have a lot of trouble putting it into 1st gear. If anybody has any clue please let me know. Thx
94YJ Sony Sound System
31x10.5 BFG All-Terrain
Flowmaster 40 series muffler
3in Performance Accessories Body Lift
BrandonParvin is offline
post #2 of 6 Old 02-26-2002, 07:10 PM
evilpsych
evilpsych's Avatar
sounds like your hydraulic throwout bearing is starting to go.. have the lines bled and refilled with clean hydraulic fluid and that should fix your prob.. i had the same prob.. that fixed it..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 6 Old 02-26-2002, 07:36 PM Thread Starter
BrandonParvin
Do you know of anybody that has a little how to on it?? If so i can get crackin on it tonite.
post #4 of 6 Old 02-27-2002, 05:48 PM
Zack Ford
I've had the same problem with my jeep about 4 or 5 months after i got it. I've drove with it like that for about 40,000 miles though i just had to let my Rpm's drop then put it in gear so it wouldn't grind. About a week ago i had my Transmission fluid drained and a synchronizer tooth fell came out w/the fluid. I'm afraid it's your synchro's and the only thing you can do is have the tranny tore down and worked on. Everybody told me it was my synchro's and they were right.
'95YJ Red 31x10.50' Hi-Lift
Hoodscoope, 4 Runnin Razorbacks under the Hood
Zack Ford is offline
post #5 of 6 Old 02-27-2002, 06:01 PM Thread Starter
BrandonParvin
Damn. Well i am going to try the hydraulic throwout bearing deal first, seems to me that it would be a lot cheaper. If that doesnt work, then it is my synchros which it better not be. Well thx for the help man.
post #6 of 6 Old 02-27-2002, 11:47 PM
Chumpbusta
It's the synchronizers! Almost guarantee it without even seeing it. jeep makes all their out of brass...they wear easy. I have replaced them before, and now I just swap the whole transmission...MUCh easier! I know its not u wanted to hear, but thats the story. Mine went out the same way...first a grind, then it gets tuff to put it in one gear, then a few of the gears, the after awhile it just goes period! Sucks. I got a recon tranny Ax-15 from www.phoenixhardparts.com. it was a good deal, but I haven't gotten my core deposit back yet...we'll see how that pans out. Good Luck!
3rd Jeep...'95 YJ 6 Cyl
4" Superlift, 1.5" shackles, 1" body lift
35x12.5x15 MT Baja Claws
Warn XDi9000 winch, full spray in liner
and all the doodads you need to do it right!
Chumpbusta is offline
Grinding Gears: What does it do acsguitar TJ Wrangler Technical Forum 4 11-05-2006 11:23 AM
I'm Grinding Gears going in and out of 4 wd bmboll TJ Wrangler Technical Forum 4 09-03-2006 06:36 PM
HELP!!! grinding gears DSPswim TJ Wrangler Technical Forum 5 05-05-2006 12:21 AM
Grinding Gears gotfish4689 YJ Wrangler Technical Forum 4 12-28-2004 07:18 PM
Grinding gears arctic jeep YJ Wrangler Technical Forum 4 07-15-2004 09:26 AM
