Grinding in every gear up, and down in my 94 4.0L - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Grinding in every gear up, and down in my 94 4.0L
Threaded Fixit Weld Washers!Why yes, we do still offer our Jeep Forum discount--code i2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 02-06-2007, 08:18 AM   #16
the dit
Seems unlikely that bad fluid would cause this probelem, especially if it happened all at once.
As has been stateed before it seems likely the clutch is not disengaging all the way, points to master /slave problem. Just because they are not leaking externally it could be an internal type leak past the seals.
89 Yj Sahara, 4.2L, 31X10.5 MT's, Weber carb, nuttered, Mustang Seats, 6" Xenon flares
2004 Dodge Ram 1500 4x4 Hemi
83 Mustang vert
the dit is offline   Reply With Quote
Unread 02-06-2007, 11:10 AM   #17
number7
fluid no good...
well actually, it was over a course of a year it got worse and worse, untill I could not shift without a grind. Then I parked it and started driving my truck. At first only between 1st and 2nd, after a few months 2nd and 3rd. It slowly got harder and harder to shift.
You may be right about the master and slave, but the clutch feels good. the hydrolic fluid was not low. I blead the hell out of it and it feels the same...
I'll let you know when I try the new fluid.
number7 is offline   Reply With Quote
Unread 02-06-2007, 04:14 PM   #18
YJ Higgins
I had a similar problem but my daughter who was driving MY JEEP at the time refused to double-clutch it. My slave cylinder was leaking at the time, the shifter was real swimmy and I eventually broke third gear (not a problem, I still had 4 more!) Finally had the new rebuilt tranny installed and slave replaced. Now it runs fine.....
YJ HIGGINS
1990 YJ White 2.5L STOCK except for third brakelight.......
It only blinks when I turn right!
YJ Higgins is offline   Reply With Quote
Unread 02-06-2007, 04:41 PM   #19
Weekender1969
This definitely sounds like synchros.
Try this, when you start to shift from 1st to second, do it real slow and let the rpms settle back to idle then ease it into 2nd. If it goes like this through all gears and doesn't grind but just a little, it's synchros. You may have limited success putting synchromesh in it but if it is as late as it seems it aint gonna help.
Your synchros get the gear you are going into spinning at the same speed as your shaft to prevent grinding. If you double clutch it and let the engine come back to idle and it shifts relatively easy, it is synchros.
Good Luck
Dale
Weekender1969 is offline   Reply With Quote
Unread 02-06-2007, 07:12 PM   #20
dc2842002
If you can shift through the gear while sittling still and the engine running (clutch pushed in obviously), then I wouls guess that it is probably not a clutch problem. I have heard of new fluid in a tranny making it shift easier (especially when switching to synthetic). But i don't know if it would help in a situation as extreme as this.
Project '94 YJ 2.5L Four banger w/AX-5 (for now), Ford 8.8 locked out back, D30 up front both w/ 4.88's, SOA on stock springs, 1" Lift shackles, SYE w/ CV driveshaft, No new tires yet still deciding on size (Prolly 35's)
DD '03 F-250 7.3l PSD w/ ZF-6 6 Speed. Ford Makes It, International Shakes It. Real Trucks Don't Have Sparkplugs
dc2842002 is offline   Reply With Quote
Unread 02-07-2007, 08:05 AM   #21
number7
I was afraid of that...
Yup, I figured that it was not an easy fix, but I was checking all possibilities.
Thanks everyone for your input.
