Grinder Got My Windshield Good... How to fix?
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
So a few months ago I had my windshield down to get to a bolt to take off my dashboard. It was super stubborn so we decided to use the grinder to get at it. That was a bad idea to rush into, neither of us thought to put rags on the windshield since the sparks were going in that direction under the glass
None the less it has scratched up and "melted" part of the wiper. So now my windshield which wasn't even a year old is no longer smooth in that area. I have tried the finest steel wool that I could find with water. And I'm not sure fine sandpaper would be any different. The steel wool only helped in the faint areas but not the worst parts. Does anyone else have an idea how to get it smooth again? I don't really want to use a coarser grain because I'm afraid that might scratch more of the windshield. Help me save my windshield. Thanks. Courtney
1995 Green Jeep Wrangler |
#2 |
Try shaving them off with a single edge razor blade. Works on my welding lens.
#3 |
same problem, excpet on a patio door, i was grinding on the balcony and i got some molten sparks and they melted into the patio door. I sanded with fine sandpaper, and steel wool, i took all the metal sparks off the window and then i took and propane torch and just heated the area up to smooth out the surface because it was very bumpy.
#4 |
Yea the razor worked awesome! It seems much smoother, you can barely feel that it is there, though I can still see the line and its mostly in my line of sight when I drive. So I think I might try 1000 grit wet sandpaper, I just bought for my friends motorcycle. It seems smooth enough to not make any damage. But much better than before, thanks for the advice all!
#5 | |
Dont use sandpaper on the windshield!!! Its tempered glass and it will crack.
Sniper Central Quote:
#6 |
Sandpaper will leave scratch marks, even if you wet sand. Get a glass (or plastic as the case may be) buffing compound and give that a try. There's a recent thread on this site relating to polishing a windshield with a product called "Flitz" (I think).
#7 |
Oh ok, no wet sanding then. I thought it would have been just as equal to the fine steel wool. Guess not. I'll have to do a search for the windshield polishing. Thanks guy I guess you saved me from making it worse on that one.
#8 | ||
#9 |
Join a 4x4 Club
If it's only a line of defect is at the wiper park area, why bother fixing it beyond the razor blade work you already did? If you keep missing with it to make it perfect (which ain't gonna happen), you will bugger it up worse for sure. Cut your losses now and move on.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
