grill/camshaft removal question - JeepForum.com
post #1 of 2 Old 12-29-2009, 07:20 PM Thread Starter
grimjeeperyj14
Is it possible to remove and install a camshaft without removing the grill. If its not possible how do I remove the grill.
Driving my Jeep is uncomfortable, loud and drafty.... and I love every minute of it
grimjeeperyj14 is offline
post #2 of 2 Old 12-29-2009, 07:45 PM
4.7stroker
remove the rad
remove the wiring harness
remove the bolts holding the grill on and lift out of the way.
I think that is pretty much it.
Don't forget cam n lifters should be installed as a set.
You will need a new cover gasket and oil seal as well as the heas gasket set. I would think de-carbon the pistons and having the head freshened by a machine shop would be in order while everything is apart.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
TJ grill removal MTDennis TJ Wrangler Technical Forum 4 12-20-2011 06:36 AM
Camshaft Removal? newagecustoms TJ Wrangler Technical Forum 9 06-21-2009 10:49 AM
TJ Grill Removal finsout TJ Wrangler Technical Forum 4 09-26-2008 12:23 PM
grill removal 98 tj clyderains TJ Wrangler Technical Forum 6 12-17-2007 02:55 PM
Front Grill Removal: How? rock2r TJ Wrangler Technical Forum 3 06-27-2005 07:50 AM
