Which GreaseAble shackles with OME springs? - JeepForum.com
post #1 of 7 Old 03-04-2012, 08:46 PM Thread Starter
shoalsjeep
Have OME springs ordered. Wanting to replace shackles with new lift. I plan on running 32/11.50 with 2.5'' OME lift (36R front and back), thinking i might need 5/8 lift shackle to help. WHich grease able shackles work with OME 36R springs? thanks!!
shoalsjeep is offline
post #2 of 7 Old 03-04-2012, 09:17 PM
moonshinefuel
Which shackle bushings work with ome springs. That's probably the question. Quick answer is ome bushings work with ome springs. However, some have been successful removing the metal sleeves in the spring eyes of the ome springs to accommodate a wider variety of bushing manufacturers you could use.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 7 Old 03-04-2012, 09:46 PM
jbolty
jbolty's Avatar
I have the full kit from MORE. much better flex than any other combination of shackles and bushings I've had before.
jbolty is offline
post #4 of 7 Old 03-05-2012, 03:19 PM Thread Starter
shoalsjeep
so, i did order new bushings from OME for the new 36R springs. But, when i order the MORE shackles OME is not listed as one of the spring companies to choose from....so how do i know which companies spring is closest to OME or does it matter since i ordered new bushings?? confused
post #5 of 7 Old 03-05-2012, 04:16 PM
jbolty
jbolty's Avatar
just pick "Other" and then the correct size bushing. Pretty sure it's 1 1/4"
jbolty is offline
post #6 of 7 Old 03-05-2012, 05:21 PM
giggityjeeper
why not get OME ones...???
that is what I did.....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #7 of 7 Old 03-05-2012, 06:09 PM
ZeroGravity
http://www.quadratec.com/products/12590_309X_PG.htm
I don't recall where I ordered mine from, but I run 36R front and back and the bushings fit the springs just fine. $90/pair, how can you go wrong?
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
Greaseable Shackles for Black Diamond 3.5" springs +Crusader+ YJ Wrangler Technical Forum 3 12-16-2008 11:51 AM
MORE greaseable shackles goatboy YJ Wrangler Technical Forum 22 08-25-2007 11:03 AM
are greaseable shackles worth it? specialk1302 YJ Wrangler Technical Forum 5 03-21-2007 12:11 AM
Greaseable shackles alienball YJ Wrangler Technical Forum 3 05-27-2006 03:22 PM
greaseable shackles condor YJ Wrangler Technical Forum 2 04-26-2006 10:51 AM
