To grease or not to grease...U-Joints - JeepForum.com
post #1 of 9 Old 03-10-2009, 08:36 AM Thread Starter
planedog
I am replacing my u-joints and wanted to get greasable joints until I realized that the only difference between standard and heavy duty joints is that the standard u-joints are greasable and the heavy duty are not drilled.
What I am wondering about is how likely I am to break the standard joint vs. the heavy duty? I like to be able to grease my u-joints because that is the only way to know their condition without removing them (if the grease comes out all four caps, the bearings are most likely ok).
So, how many of you are running the standard, greasable u-joints? Thanks.
planedog is offline
post #2 of 9 Old 03-10-2009, 08:38 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I have always run standard greasables.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 9 Old 03-10-2009, 08:40 AM
DixiesCJ3B
I would def get the greasable ones. Being able to grease them in my opinion will make them last longer.
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline
post #4 of 9 Old 03-10-2009, 10:02 AM
70sElvis
I have always used greaseable but decided to try some lifetime warranty non-greaseable this time. Figured with a lifetime warranty, they must be pretty good. If they end up being crap, not too expensive or too hard to replace them again with greaseable. I think it is pretty much personal preference.
70sElvis is offline
post #5 of 9 Old 03-10-2009, 11:11 AM Thread Starter
planedog
I was surprised when I compared the two at Advance and Auto Zone yesterday. There is absolutely no visual difference except for the grease fitting. They even charge about $5 more for the non-drilled, heavy duty model. I guess the extra mass makes them stronger.
planedog is offline
post #6 of 9 Old 03-10-2009, 11:32 AM
MLJeeper
MLJeeper's Avatar
Depends on where for me. I run non greasables in the axle shafts and greasables on the drive shafts. With your current set up its a non issue, run what you want.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #7 of 9 Old 03-10-2009, 07:31 PM
Jeeples
Jeeples's Avatar
Also, as an install tip, take all four caps off each U-joint and pump out all the grease inside the U-joint. That stuff is generally only meant to prevent rusting during shipping and storage and breaks down very quickly, causing premature failure of the needle bearings.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #8 of 9 Old 03-10-2009, 07:42 PM
BeerJ
I always went with whichever had a lifetime warrenty. That way you only buy one. The local Autozone people apperently cant tell the difference between a stock joint and one of their lifetime warranty ones. A friend of mine blew a joint so I took it in and got him a brand new one for free. And so goes the circle of life
Originally Posted by toates89 View Post
Now i am in love with beer. I have had around 100 beers.
BeerJ is offline
post #9 of 9 Old 03-10-2009, 07:43 PM
Joe1167
GREASEABLE!
if not, your bearings will turn to dust. just happened to me.
Joe1167 is offline
Advice Needed: Red Grease, Marine Grease, Synthetic Grease, Marine Synthetic mixes CB3 TJ Wrangler Technical Forum 5 11-25-2009 12:21 AM
Any one using marine grease in there u joints fireshadow YJ Wrangler Technical Forum 4 08-31-2009 12:06 PM
Need to grease the ball joints? BChamberlin TJ Wrangler Technical Forum 3 05-29-2008 04:49 PM
How do I grease these U-joints? ElvisV04290 YJ Wrangler Technical Forum 2 05-20-2007 08:50 PM
Grease CV Joints? giallojeep TJ Wrangler Technical Forum 6 07-30-2006 03:28 PM
