got a slight problem - JeepForum.com
post #1 of 3 Old 10-03-2011, 06:22 AM Thread Starter
krahnj
I'm doing a slight restoration of my floors in my 91 yj and encountered a slight problem with some bolt removal. On removal of the rear bench seat i snapped a bolt clean flush with the floor. I have the head of the bolt but the rest is still threaded into the floor. any ideas on how to get that out would be helpfull. I would hate to drill it out and re tap the hole.
krahnj is offline
post #2 of 3 Old 10-03-2011, 06:27 AM
grandboost98
get a set of easy outs. trust me, youll need them
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 3 Old 10-03-2011, 06:43 AM
bogleparsons
Or get a left handed drill bit.
If it won't back out you have a hole for the easy out.
Also soak that bad boy in some PB blaster for a day or 2
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
Lift done... slight problem with shifting?!? 98 Sahara TJ Wrangler Technical Forum 8 10-04-2011 10:18 AM
slight electrial problem sqanto TJ Wrangler Technical Forum 2 08-22-2010 11:11 AM
Slight Posi-Lock problem jeepkween YJ Wrangler Technical Forum 1 09-17-2009 10:16 AM
Slight missing problem jeepermeo2 TJ Wrangler Technical Forum 20 02-09-2007 06:50 PM
slight problem after nutter mod jeepercreeper77 YJ Wrangler Technical Forum 4 12-12-2006 06:16 PM
