got me a roll cage - Page 2 - JeepForum.com
post #16 of 20 Old 08-12-2011, 03:59 PM
bigbossd1030
Its a monster!
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #17 of 20 Old 08-12-2011, 04:16 PM
Xpress
Isn't the point of climbing an obstacle, NOT to roll?
For what they are, stock roll bars are good for the usual wheeling. A roll cage is what you need if you're crazy enough to want to roll...?
All about that unibody life.
Xpress is offline
post #18 of 20 Old 08-12-2011, 04:21 PM
92 Green YJ
92 Green YJ's Avatar
Nobody ever wants to roll or plans to roll. But bad things happen. I've had a few too many close calls in my day to want to trust the stock roll bar personally. At TDS this past year I almost rolled twice in a matter of about 2 minutes. Scary enough to make me want to upgrade. Imalso had this little flop incident also at TDS a few years back. Whole jeep was resting on the roll bar. Luckily it was a gentle flop. But still.
And no I didn't plan on that happening. A buddy rolled into camp round midnight and said he wanted to do a quick shake down since he had just rebuilt his transfer case. I had found that notch a few hundred yards from camp that afternoon, so we went for a quick run. That was the result. We both got stuck. Had to hoof it back to camp to wake someone else up to come yank us out
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #19 of 20 Old 08-12-2011, 04:23 PM
Xpress
^See that's where you need a heavier duty roll cage.
Xpress is offline
post #20 of 20 Old 08-12-2011, 05:06 PM
newheep
It may not be a jeep, but this happened on the drive back to camp, all the heavy wheeling had already been done.
newheep is offline
Roll cage padding on aftermarket cage UTWeezul TJ Wrangler Technical Forum 5 06-11-2013 12:51 AM
Roll Cage in JK. Good Enough in a Bad Roll? fastRob JK Wrangler Technical Forum 61 05-28-2012 06:52 PM
TJ ROLL CAGE DIMENSIONS or solidworks cage model rtbtitans50 TJ Wrangler Technical Forum 2 03-30-2011 03:34 PM
In Dash Roll Cage or Sport Roll Cage derdawa TJ Wrangler Technical Forum 4 05-11-2009 12:08 PM
Roll Cage - Torx bit "Key" to remove cage Greg_Volkman TJ Wrangler Technical Forum 10 07-17-2006 06:37 PM
