Got jeep back from shop, coolant level low, jeep running cold. - JeepForum.com
post #1 of 5 Old 10-30-2010, 07:04 PM Thread Starter
kainers
Hi there,
Just got the jeep back from getting my waterpump changed, along with some other things. I opened the hood and saw the cap for the coolant reservoir was missing, and the reservoir was empty. I opened the rad cap, and I don't see any coolant. Meaning, I can see the fins in the radiator. It's wet on the inside though, not bone dry or anything. The cap had some coolant drops fall off of it when I took it off.
Should the coolant be above the rad fins? Is there anyway to see how much coolant is in there?
He said there wasnt a thermostat in there, so he added one when he changed the waterpump. The jeeps temp gauge only went up to the 1/4 mark on the gauge. It should be around the middle?
I drove it about 10 miles, it was pretty chilly out, and I have an electrical fan. Dunno if those are any factors.
kainers is offline
post #2 of 5 Old 10-30-2010, 07:10 PM
TheNewbie
It should usually get up to temp within 10 miles, but not always. But low coolant will NEVER cause it to run cold. It will work like normal until it gets low to the point where it can't curculate through the engine and then it will overheat right away.
I would fill it up with a 50/50 coolant mix and fill the reservoir as well. But as far as it running cool from being too low... it just doesn't ahppen so I'd say you're fine.
If you have an electric fan and it was running all the time in cold temps I could see it only running around 1/4 of the way up. Or your thermostat could be stuck open as well. None of those things will hurt your jeep though. Running cool isn't going to do immediate damage to your engine like overheating, but I'd still check out those things as soon as possible.
If it never gets up to temp I'd start by checking the thermostat. They are cheap.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 5 Old 10-30-2010, 07:16 PM
Budke
Gonna thread jack real quick.
What happens when the jeep is always running cold?
My jeep only gets up to 1/4 mark and stays no matter how much driving.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #4 of 5 Old 10-30-2010, 07:21 PM Thread Starter
kainers
Thanks for the quick reply. Super-fast!
I edited my first post a little as I realized it looked like one issue. I was worried about low coolant but also the low temp from possibly the wrong tstat. I forgot to mention he added a new tstat when he changed the pump. But it's good to know that
Even with low coolant the engine didn't over-heat.
kainers is offline
post #5 of 5 Old 10-30-2010, 08:51 PM
dodger889
They might not have burped the cooling system. Sometimes this might take a few heating and cooling cycles to get all the air out. Just keep the reservoir full to the hot mark for just a bit till it quits dropping the level down.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Jeep running cold, bad? deerhunter1911 TJ Wrangler Technical Forum 12 12-09-2013 10:50 AM
Jeep came back from the shop. Should I return iut for a 4wd light Muaymendez YJ Wrangler Technical Forum 5 05-04-2010 09:43 PM
what will level out my jeep front to back? 45caljeep TJ Wrangler Technical Forum 5 03-27-2010 03:03 AM
I will be glad to have my jeep back from the shop. jc23jc23 YJ Wrangler Technical Forum 4 09-30-2004 09:25 AM
just got jeep back out of shop redneckjeepr TJ Wrangler Technical Forum 2 06-04-2004 02:26 AM
