Got a Ford 8.8! now i have some questions - Page 3 - JeepForum.com
post #31 of 40 Old 08-05-2010, 12:21 PM Thread Starter
mikeyford3
[QUOTE=Sungard;9908119]out of curiosity. please pardon my ignorance but, what you do with the front axle? is it only swapping the rear with ford 8.8 or you do something with the front end?
well im either getting a 4.10 dana 30 front axle or i am searching for a high pinion dana 44 to throw under there. Im starting with the rear. For one im runnning 35's and two, Im a college student with a child on a budget..
mikeyford3 is offline
post #32 of 40 Old 08-06-2010, 04:56 PM
SpideYJeep
Originally Posted by mikeyford3 View Post
SNIP!
See, education is a good thing! Without college, mikey wouldn't have known to keep that child on a budget! The child would spend everything mikey earned. Instead, mikey has money to spend on the Jeep!
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #33 of 40 Old 08-06-2010, 05:24 PM
ugmo
Originally Posted by Pokeman View Post
I used my stock drive shaft.
I used all the exploder stock brake lines/hoses with no issue.
I used my yj stock ebrake cables
KISS!!!!!
I did the same thing (per the jedi method), but I eventually went to the sye.
ugmo is offline
post #34 of 40 Old 08-06-2010, 05:26 PM
ugmo
Originally Posted by imstillatwork View Post
anything under 200 is a great deal.
You'll want to get a flange adapter that uses 1310 u joints, and bolts to the 8.8 pinion flange. Dana/Spicer part number 2-2-1379. Yes 1330/1310 hybrid u joints are available but I think a one time $30 flange that lets you run normal 1310 joints is worth it.
The diff cover is incredibly thin sheet metal, so plan on getting a beefier one.
I have the 8.8 in the garage right now, so can't comment on installation. Paid 150 with no gears (need 4.88's anyways) and LSD carrier (wanted open for lock-right /aussie, owell.)
If anyone wants to trade and LSD carrier for an open lemme know
Actually, he has a 94 plus looks like he even upgraded to a 98 t/c n shaft, so he'll be fine with the exploders 1330 flange. No hybrid u-joint needed.
+1000 on diff cover
ugmo is offline
post #35 of 40 Old 08-06-2010, 05:31 PM
ugmo
i wasnt going to weld them on 9/16 of an inch over i was just saying when i weld them on they get welded on 9/16 of an inch over towards my pumpkin.. and the shock mounts im thinking i could just weld them after i get the rear in...
You want to move the perches away from the pumpkin.
ugmo is offline
post #36 of 40 Old 08-06-2010, 08:48 PM
RockWoRM
RockWoRM's Avatar
no, no, no... the measurement goes "outboard" of the fac. perch positions. I hope you marked it that way before cutting. if not, then you'll have to move them back outward 1 1/8".
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #37 of 40 Old 08-06-2010, 09:31 PM
CreepyCrawler95
do you know wht spline count it is?
CreepyCrawler95 is offline
post #38 of 40 Old 08-06-2010, 10:48 PM
timatoe
timatoe's Avatar
hey timatoe did you have to lengthen or shorten any of the cables?
Sorry, I just saw this. No, I used the Ford factory cables with no modification other than the one that was looped over the bracket.
timatoe is offline
post #39 of 40 Old 08-09-2010, 11:18 PM Thread Starter
mikeyford3
Lol well luckily its not even a year yet! but for now i put some money aside for me to play with my toys lol and most of the money goes towards the heep lol
post #40 of 40 Old 08-09-2010, 11:21 PM Thread Starter
mikeyford3
WRM
Lol and actually i measured out towards the brakes but i got confused on the way someone typed something and asked again..
Ford 8.8 Questions Towny72 YJ Wrangler Technical Forum 17 05-08-2009 02:09 PM
ford 8.8 questions demoguru YJ Wrangler Technical Forum 17 03-23-2007 08:05 PM
Ford 8.8 Questions alvinl TJ Wrangler Technical Forum 8 02-26-2007 02:03 PM
Ford 8.8 Questions emcee5000 TJ Wrangler Technical Forum 1 05-16-2005 09:16 AM
Ford 8.8 questions BudmanV6 YJ Wrangler Technical Forum 14 03-19-2005 02:16 AM
