Got a Ford 8.8! now i have some questions - Page 2 - JeepForum.com
post #16 of 40 Old 07-02-2010, 07:39 AM Thread Starter
mikeyford3
i thought there was 3.73/4.10
mikeyford3 is offline
post #17 of 40 Old 07-02-2010, 10:16 AM
jeepster93
jeepster93's Avatar
Nope.
One carrier.
jeepster93 is offline
post #18 of 40 Old 07-02-2010, 10:50 AM
imstillatwork
The D35 has a break, but at different gears
imstillatwork is offline
post #19 of 40 Old 07-18-2010, 07:01 PM Thread Starter
mikeyford3
okay well i got the 8.8 it came with everything except the rotors.. would it be better to use the jeep e brake cables or fords ebrake cables?
post #20 of 40 Old 07-18-2010, 10:10 PM
timatoe
timatoe's Avatar
I used the Ford cables to the bracket on the Jeep where the stock line runs to.
Like this.....
timatoe is offline
post #21 of 40 Old 07-19-2010, 10:11 AM Thread Starter
mikeyford3
hey timatoe did you have to lengthen or shorten any of the cables?
post #22 of 40 Old 08-03-2010, 02:05 PM Thread Starter
mikeyford3
okay so im cutting the perches off tonight.. i have to move both 9/16 over correct? and why do i need two passenger side brake line?
post #23 of 40 Old 08-03-2010, 02:12 PM
jbolty
jbolty's Avatar
There is more to it than moving the perches over; they also have to be positioned to set the proper pinion angle. That needs to be done with the axle under the jeep and with it sitting at ride height. (weight on the springs)
You need two passenger side soft lines because the stock one on the drivers side is molded into the distribution block. If you swap out the left one you can connect it all up using your existing hard lines.
jbolty is offline
post #24 of 40 Old 08-03-2010, 04:09 PM Thread Starter
mikeyford3
thankssss
post #25 of 40 Old 08-03-2010, 07:00 PM
RockWoRM
RockWoRM's Avatar
as has been said, yes. but for now, unless you've got your d-line stuff all dialed in, just scribe/score the marks on the tube. When everything else is ready to go, mock it up and you can set your pinion angle and weld the perches all at one time.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #26 of 40 Old 08-04-2010, 08:30 PM Thread Starter
mikeyford3
i wasnt going to weld them on 9/16 of an inch over i was just saying when i weld them on they get welded on 9/16 of an inch over towards my pumpkin.. and the shock mounts im thinking i could just weld them after i get the rear in...
post #27 of 40 Old 08-04-2010, 08:46 PM
Krochus
If you can't cut off the explorer perches without hacking them up,
Sure you can........but you gotta have the correct equipment. The arc gouger I used peels em off like opening a banana without mangling anything
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #28 of 40 Old 08-04-2010, 08:51 PM Thread Starter
mikeyford3
well i got the perches off, they are fine! Axles tubes are fine also.
post #29 of 40 Old 08-05-2010, 04:11 AM
Sungard
out of curiosity. please pardon my ignorance but, what you do with the front axle? is it only swapping the rear with ford 8.8 or you do something with the front end?
Thanks
'95 YJ, 4.0,(4:10)RE 2.5"+5/8 Booms,1"BL & 33"
'13 WK2 TrailHawk(V6)
'04 WJ,4.7HO,Overland,(SOLD)
Sungard is offline
post #30 of 40 Old 08-05-2010, 08:25 AM
Krochus
Thanks
Our jeeps actually already have a resonably stout front axle. With regards to axles luckily us yj'ers only got screwed in the rear......
Krochus is offline
Ford 8.8 Questions Towny72 YJ Wrangler Technical Forum 17 05-08-2009 02:09 PM
ford 8.8 questions demoguru YJ Wrangler Technical Forum 17 03-23-2007 08:05 PM
Ford 8.8 Questions alvinl TJ Wrangler Technical Forum 8 02-26-2007 02:03 PM
Ford 8.8 Questions emcee5000 TJ Wrangler Technical Forum 1 05-16-2005 09:16 AM
Ford 8.8 questions BudmanV6 YJ Wrangler Technical Forum 14 03-19-2005 02:16 AM
