Good Spark, No Start - JeepForum.com
post #1 of 3 Old 12-17-2011, 02:39 PM Thread Starter
gatorbubba
I have been surfing the forums and haven't quite found the answer I'm looking for. So I recently rebuilt my throttle body to fix high idling, I was able to crank it back up and run it. Then a day later, I cranked it up and let it idle for around 15 min, then I cut it off, at which point in dieseled pretty severely and now it won't start. I got spark and fuel going into the intake. Any ideas?
gatorbubba is offline
post #2 of 3 Old 12-17-2011, 03:29 PM
DAVE4273
hmmmmmmm.... Thats a good one
David
DAVE4273 is offline
post #3 of 3 Old 12-17-2011, 03:46 PM Thread Starter
gatorbubba
Update: So I disconnected the injector and it started right up, and would idle smoothly indefinitely. I then put the wire connector back on and restarted, very rough idle but works ok at open throttle. I looked in the throttle body with the injector connected, and it looks to be putting too much fuel in at idle. Is this a sign that my injector is bad/leaking? Or could it be the IAC? How can I check to isolate which one is causing the problem? I know the temperature sensor is working properly since I tested it with a mutlimeter and got good readings. Got to love the TBI
94 yj no spark, no start 97mrnsgt YJ Wrangler Technical Forum 15 05-23-2014 06:04 PM
No spark, no start.... AnonymousD YJ Wrangler Technical Forum 5 09-01-2011 09:28 AM
No Spark, Where to Start? Towny72 YJ Wrangler Technical Forum 22 10-26-2010 12:55 AM
No spark on start, one spark on run. Benny88 YJ Wrangler Technical Forum 7 03-05-2010 03:38 PM
Won't start 2.5L No spark xeroGuitar YJ Wrangler Technical Forum 3 07-16-2008 04:24 PM
