Good Idea Bad Idea? - JeepForum.com
post #1 of 2 Old 03-06-2002, 10:35 PM Thread Starter
Coot
Good Idea Bad Idea?
Would it be a good idea or a bad idea to do a spring over lift with the stock springs? and if I did that what size tires would I be able put under it?
92 Jeep YJ, 4 Banger, Cold air intake, Electric fan, 1 inch motor mount lift, 8.8 rear axle Limited Slip 4.10's, SOA, 2 inch body, 35x12.5 Pro Comp MT on 15x8 AR-767
Coot is offline
post #2 of 2 Old 03-06-2002, 10:41 PM
kidwired
kidwired's Avatar
its a great idea!
it will ride like a caddy and flex like that lil brunette you used to know. :P
be prepared to replace them frequently. they will go flat.
94 yj SOA +3.5", 35" swampers.
kidwired is offline
Undercoating. Good idea or bad idea? fatjeepkid JK Wrangler Technical Forum 17 05-30-2010 08:17 AM
tie rod mod.---good idea? PatriotCrawler TJ Wrangler Technical Forum 6 03-18-2008 05:03 PM
Herculining hard top... good idea? bad idea? ScottJ83 TJ Wrangler Technical Forum 19 10-27-2006 04:31 PM
Is this a good idea? noselfcontrol TJ Wrangler Technical Forum 5 06-05-2006 06:18 PM
good idea or bad idea? hardwarp TJ Wrangler Technical Forum 10 12-06-2004 09:01 PM
