is this good? - JeepForum.com
post #1 of 6 Old 09-13-2011, 06:07 PM Thread Starter
houd1n1
is this good?
I would like to do a 4" rc lift, 5/8 M.O.R.E boomerang shackle lift, 1" Body lift(not sure what kind or what is good). 33 12.50 r15 with d window wheels. can someone give me some pointers and input on all these things. I heard something about angle change with shackle lift or what not, is that bad and how can I fix that.
houd1n1 is offline
post #2 of 6 Old 09-13-2011, 06:10 PM
jbeebe
sounds like a pretty good plan.
a 5/8 shackle will add to your drive shaft angle, but i'm willing to bet you won't get many vibes with that set-up. besides the brands, it's about the same as my setup.
what exactly do you want pointers on?
jbeebe is offline
post #3 of 6 Old 09-13-2011, 06:15 PM
Spuznick242
Sounds like you might need to extend your brake lines and deff. check the drive shaft angles with that but thats all stuff you can figure out when you start or with some more searching. I'm personally against RC but that's just my opion (and yes, I'm going ot say it), I just dont like their products, it comes with a life time warrenty, but your going to have to use that warrenty no matter how hard you wheel. But the tire size to lift hight is pretty good.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #4 of 6 Old 09-13-2011, 06:20 PM
jbeebe
i got extended brake lines in the front, but i do a lot of crawling. unless you hit big rocks, you probably won't need them.
although every jeep is different, i think you'll be OK as far as vibes go.
jbeebe is offline
post #5 of 6 Old 09-13-2011, 10:37 PM Thread Starter
houd1n1
for the drive shaft angle, what am i checking for exactly? and I know a lot of people are against RC but I want to try them out. and I use my jeep as my DD but I occasionally go off roading. What are some good but not to expensive tires? If I do get vibes what should i check?
houd1n1 is offline
post #6 of 6 Old 09-13-2011, 11:12 PM
jeepnbrett
http://www.4xshaft.com/driveline101.html
Here is some great info on driveline angle from Tom Woods.
With a 4 inch lift plus the shackles I will be shocked if you don't have vibration issues. You can give it a try but plan on an SYE with a CV shaft.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
molshove's thread of good JK questions with not so good JK answers! mattlago JK Wrangler Technical Forum 160 12-30-2011 02:11 PM
TPS good wiring, good Code p0121, low voltage, Possible Causes??? ryankikta TJ Wrangler Technical Forum 2 10-02-2009 07:32 AM
New grears for $700 installed good price or sounds to good to be true? sethco JK Wrangler Technical Forum 24 08-10-2009 12:15 PM
8.8 is a good rear. what is good front axle? need4spd YJ Wrangler Technical Forum 20 09-13-2007 03:01 PM
whats the cheapest way to lift,lock,gear and still wheel good and handle good EKUSMC TJ Wrangler Technical Forum 16 03-31-2006 08:35 AM
